08-11-2015 07:24 AM - edited 03-17-2019 03:57 AM
I don't understand the following:
A customer with CUCM and CUBE can call any number but only one number of a number range, he can't reach. If he calls this number, the CUBE sends an "500 internal server error" to the CUCM after the 200OK from the called destination arrived at the external interface of the CUBE. Does anybody have an idea why this could happen?
Best regards
ecstaticduck
08-11-2015 07:40 AM
Can you post "sh run" and "debug ccsip messages"?
08-12-2015 12:54 AM
5393779: Jul 13 07:04:08.475 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:1234@1.2.3.4:5060 SIP/2.0
Via: SIP/2.0/TCP 5.6.7.8:5060;branch=z9hG4bK8f6d4b06f77e
From: "TnC" <sip:5678@5.6.7.8>;tag=486574~7a508d76-4fd0-4164-905a-6c6e841f23a1-53739009
To: <sip:1234@1.2.3.4>
Date: Mon, 13 Jul 2015 07:04:08 GMT
Call-ID: 11-12-13-14@5.6.7.8
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM9.1
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Cisco-Guid: 1504618880-0000065536-0000015064-0856203274
Session-Expires: 1800
P-Asserted-Identity: "TnC" <sip:5678@5.6.7.8>
Remote-Party-ID: "TnC" <sip:5678@5.6.7.8>;party=calling;screen=yes;privacy=off
Contact: <sip:5678@5.6.7.8:5060;transport=tcp>
Max-Forwards: 70
Content-Type: application/sdp
Content-Length: 211
v=0
o=CiscoSystemsCCM-SIP 486574 1 IN IP4 5.6.7.8
s=SIP Call
c=IN IP4 1.2.3.4
t=0 0
m=audio 17316 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
5393780: Jul 13 07:04:08.487 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:1234@10.20.30.40:5060 SIP/2.0
Via: SIP/2.0/UDP 1.2.3.5:5060;branch=z9hG4bK92AB5B128C
From: "TnC" <sip:5678;phone-context=national@rt01.ab.local>;tag=DDAD9628-1C77
To: <sip:1234;phone-context=national@10.20.30.40>
Call-ID: 21-22-23-24@rt01.ab.local
Supported: 100rel,timer,resource-priority,replaces,histinfo
Min-SE: 1800
User-Agent: Cisco-SIPGateway/IOS-15.3.3.M
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1436771048
Contact: <sip:5678@1.2.3.5:5060>
History-Info: <sip:1234@10.20.30.40:5060>;index=1
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 69
Content-Disposition: session;handling=required
Content-Length: 243
v=0
o=CiscoSystemsSIP-GW-UserAgent 543 4395 IN IP4 1.2.3.5
s=SIP Call
c=IN IP4 1.2.3.5
t=0 0
m=audio 31758 RTP/AVP 8 101
c=IN IP4 1.2.3.5
a=fmtp:101 0-15
a=ptime:20
5393781: Jul 13 07:04:08.487 UTC: //10356619/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Server: Cisco-SIPGateway/IOS-15.3.3.M
Content-Length: 0
5393782: Jul 13 07:04:08.491 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
From: "TnC"<sip:5678;phone-context=national@rt01.ab.local>;tag=DDAD9628-1C77
CSeq: 101 INVITE
Content-Length: 0
Received:
SIP/2.0 100 Trying
CSeq: 101 INVITE
Content-Length: 0
5393792: Jul 13 07:04:08.915 UTC: //10356619/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 183 Session Progress
To: <sip:1234@1.2.3.4>;tag=DDAD97D8-995
CSeq: 101 INVITE
Contact: <sip:1234@1.2.3.4:5060;transport=tcp>
Content-Length: 256
v=0
o=CiscoSystemsSIP-GW-UserAgent 5836 5971 IN IP4 1.2.3.4
s=SIP Call
c=IN IP4 1.2.3.4
t=0 0
m=audio 32614 RTP/AVP 8 101
c=IN IP4 1.2.3.4
a=fmtp:101 0-16
a=ptime:20
a=label:Audio
5393793: Jul 13 07:04:09.271 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 180 Ringing
From: "TnC"<sip:5678;phone-context=national@10.20.30.40>;tag=DDAD9628-1C77
To: <sip:1234;phone-context=national@10.20.30.40>;tag=75395
CSeq: 101 INVITE
Contact: <sip:1234@10.20.30.40:5060>
User-Agent: Nortel SESM 17.0.7.13
Supported: com.nortelnetworks.firewall,p-3rdpartycontrol,nosec,join,x-nortel-sipvc,gin
Content-Length: 0
5393794: Jul 13 07:04:09.271 UTC: //10356619/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 101 INVITE
Contact: <sip:01234@1.2.3.4:5060;transport=tcp>
Content-Length: 0
5393799: Jul 13 07:04:15.635 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
CSeq: 101 INVITE
Contact: <sip:1234@10.20.30.40:5060;maddr=10.20.30.40>
Supported: replaces,tdialog
Allow: INVITE,BYE,CANCEL,ACK,REGISTER,SUBSCRIBE,NOTIFY,MESSAGE,INFO,REFER,OPTIONS,PUBLISH,PRACK
Require: timer
Session-Expires: 1800;refresher=uac
Content-Length: 223
v=0
o=- 5571 2 IN IP4 193.246.243.68
s=session
b=CT:1000
t=0 0
m=audio 45312 RTP/AVP 8 101
c=IN IP4 193.246.243.68
a=label:Audio
a=sendrecv
a=fmtp:101 0-16
5393800: Jul 13 07:04:15.639 UTC: //10356619/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 500 Internal Server Error
CSeq: 101 INVITE
Content-Length: 0
5393801: Jul 13 07:04:15.639 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:1234@10.20.30.40:5060 SIP/2.0
Via: SIP/2.0/UDP 1.2.3.5:5060;branch=z9hG4bK92AB5D4EB
From: "TnC" <sip:5678@rt01.ab.local>;tag=DDAD9628-1C77
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
5393802: Jul 13 07:04:15.659 UTC: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:1234@1.2.3.4:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
5393803: Jul 13 07:04:15.663 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:1234@10.20.30.40:5060 SIP/2.0
Via: SIP/2.0/UDP 1.2.3.5:5060;branch=z9hG4bK92AB5E123F
Max-Forwards: 70
Timestamp: 1436771055
CSeq: 102 BYE
Reason: Q.850;cause=16
P-RTP-Stat: PS=332,OS=53120,PR=0,OR=0,PL=0,JI=0,LA=0,DU=0
Content-Length: 0
5393804: Jul 13 07:04:15.671 UTC: //10356620/59AEA9800000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 200 OK
From: "TnC"<sip:5678@rt01.ab.local>;tag=DDAD9628-1C77
CSeq: 102 BYE
Content-Length: 0
08-12-2015 02:56 AM
Please share your config along with debug ccsip verb, debug voice ccapi, debug voice dialpeer
08-12-2015 03:07 AM
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
service sequence-numbers
hostname rt01
boot-start-marker
boot-end-marker
aqm-register-fnf
logging buffered 64000
no logging console
enable secret 4 XXYYZZ
aaa new-model
aaa authentication login VTY group radius local
aaa authentication login CONSOLE local
aaa session-id common
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause rootguard
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
errdisable recovery cause link-flap
errdisable recovery interval 180
no ip source-route
ip icmp rate-limit unreachable 1000
no ip domain lookup
ip domain name kunde.ab
ip cef
no ipv6 cef
voice-card 0
dsp services dspfarm
voice call send-alert
voice call convert-discpi-to-prog always
voice call carrier capacity active
voice rtp send-recv
voice service voip
ip address trusted list
no ip address trusted authenticate
address-hiding
mode border-element
allow-connections sip to sip
fax protocol pass-through g711alaw
sip
min-se 1100 session-expires 1100
source filter
no anat
early-offer forced
history-info
midcall-signaling passthru
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice class sip-profiles 110
request INVITE sip-header From modify "sip:([1-9]........[0-9].*)" "sip:000\1;"
request INVITE sip-header From modify "sip:([1-9].......[0-9])" "sip:00\1;"
request INVITE sip-header Remote-Party-ID modify "sip:([1-9]........[0-9].*)" "sip:000\1;"
request INVITE sip-header Remote-Party-ID modify "sip:([1-9].......[0-9])" "sip:00\1;"
request INVITE sip-header Contact modify "sip:([1-9]........[0-9].*)" "sip:000\1;"
request INVITE sip-header Contact modify "sip:([1-9].......[0-9])" "sip:00\1;"
voice class sip-profiles 100
request INVITE sip-header To modify "sip:0([1-9].*)@" "sip:\1;phone-context=national@"
request INVITE sip-header To modify "sip:00(.*)@" "sip:\1;phone-context=international@"
request INVITE sip-header History-Info modify "Reason=sip;" "Reason=sip%3b"
request INVITE sip-header History-Info modify "cause=" "cause%3d"
request INVITE sip-header History-Info modify "text=" "text%3d"
request INVITE sip-header History-Info modify "sip:00([1-9].*" "sip:\1;phone-context=national"
request INVITE sip-header P-Asserted-Identity modify "sip:zzzzz([4-8][0-9]..)@" "sip:81844\1;phone-context=national@"
request INVITE sip-header P-Asserted-Identity modify "sip:zzzzz(8[0-9]..)@" "sip:zzzzz\1;phone-context=national@"
request INVITE sip-header P-Asserted-Identity modify "sip:zzzzz(9[0-9]..)@" "sip:zzzzz\1;phone-context=national@"
request INVITE sip-header Diversion modify "sip:00(.*)@" "sip:\1;phone-context=national@"
request INVITE sip-header From modify "sip:(.........)@" "sip:\1;phone-context=national@"
request INVITE sip-header From modify "sip:(.........[0-9].*)@" "sip:\1;phone-context=international@"
request REINVITE sip-header SIP-Req-URI modify "anonymous" "zzzzzzzzzzz"
voice translation-rule 1
rule 1 /\(.+\)/ /0\1/
rule 2 /^$/ /xxxxxxxxxxx/
voice translation-rule 2
rule 1 /wwwww\([4-8]...$\)/ /xxxxxxx\1/
rule 2 /wwwww\(40[5-7].\)/ /xxxxxxx\1/
rule 3 /wwwww\(437[3-5]\)/ /xxxxxxx\1/
voice translation-rule 3
rule 1 /^0/ //
voice translation-rule 4
rule 1 /^yy/ //
voice translation-rule 5
voice translation-rule 10
rule 1 /^yy/ //
rule 2 /000yy\(.........\)/ /\1/
rule 3 /000/ /00\1/
rule 4 /00yy\(.......\)/ /yy\1/
rule 5 /00/ /\1/
rule 6 /[+]yy\(.........\)/ /\1/
voice translation-rule 11
rule 1 /^yy/ //
rule 2 /000yy\(a[a-c].......\)/ /zzzzzzzz\1/
rule 3 /000yy\(.........\)/ /0\1/
rule 4 /000/ /00\1/
rule 5 /00yy\(.......\)/ /041\1/
rule 6 /00\(a[a-c].......\)/ /zzzzzzzz\1/
rule 7 /00/ /0\1/
voice translation-rule 30
rule 1 /000yy\(a[a-c].......\)/ /zzzzzzzz\1/
rule 2 /00\(a[a-c].......\)/ /zzzzzzzz\1/
rule 3 /^0/ //
voice translation-profile voip-gate_IN
translate calling 1
translate called 2
voice translation-profile voip-gate_OUT
translate calling 10
translate called 3
license udi pid CISCO2911/K9 sn FGL17431077
hw-module pvdm 0/0
object-group network Provider_Servers
ggg.hhh.iii.0 255.255.255.0
ggg.hhh.jjj.0 255.255.255.0
ggg.hhh.kkk.0 255.255.255.0
vtp domain kunde.ab
vtp mode transparent
username AABBCC secret 5 XXYYZZ
redundancy
ip tcp window-size 65535
ip tcp synwait-time 10
ip tcp path-mtu-discovery
ip tftp source-interface GigabitEthernet0/0
ip ssh time-out 30
ip ssh source-interface GigabitEthernet0/0
ip ssh version 2
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip address 1.2.3.4 255.255.255.0
no ip redirects
no ip proxy-arp
duplex auto
speed auto
arp timeout 300
interface GigabitEthernet0/1
ip address 1.2.3.5 255.255.255.0
ip access-group Provider_IN in
duplex auto
speed auto
ip access-list extended Provider_IN
permit udp object-group Provider_Servers host 1.2.3.5
permit icmp any any
deny ip any any log
logging source-interface GigabitEthernet0/0
logging host sag.ich.sicher.nicht
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
sccp local GigabitEthernet0/0
sccp ccm cucm1 identifier 1 version 7.0
sccp ccm cucm2 identifier 2 version 7.0
sccp
sccp ccm group 1
bind interface GigabitEthernet0/0
associate ccm 1 priority 1
associate ccm 2 priority 2
associate profile 2 register ABCD-rt01
associate profile 1 register MTP-rt01
dspfarm profile 2 transcode
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
maximum sessions 12
associate application SCCP
dspfarm profile 1 mtp
codec g711alaw
maximum sessions software 150
dial-peer voice 10 voip
description *** SIP to Provider ***
translation-profile outgoing Provider_OUT
preference 1
destination-pattern 0T
session protocol sipv2
session target ipv4:10.20.30.40
session transport udp
voice-class sip localhost dns:rt01.ab.local
voice-class sip profiles 100
voice-class sip options-keepalive up-interval 30 down-interval 15 retry 3
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 101 voip
description *** SIP to Primary CUCM ***
preference 1
destination-pattern zzzzzzz....
session target ipv4:5.6.7.8
voice-class sip profiles 110
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
ip qos dscp cs3 signaling
no vad
dial-peer voice 102 voip
description *** SIP to Secondary CUCM ***
preference 2
session target ipv4:5.6.7.7
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 100 voip
description *** SIP from Provider ***
translation-profile incoming Provider_IN
incoming called-number zzzzz....
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 20 voip
description *** SIP from CUCM ***
incoming called-number 0T
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 110 voip
incoming called-number zzzzzzz[a-c].
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 111 voip
preference 1
destination-pattern zzzzzzzzz[a-c].
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 112 voip
preference 2
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 120 voip
incoming called-number zzzzzzzz[a-c]
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 121 voip
preference 1
destination-pattern zzzzzzzzzz[a-c]
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
dial-peer voice 122 voip
preference 2
dtmf-relay rtp-nte
codec g711alaw
fax rate 9600
no vad
gateway
timer receive-rtp 1200
sip-ua
no remote-party-id
retry invite 3
connection-reuse
gatekeeper
shutdown
08-12-2015 03:47 AM
I don't see bind interface command anyware. You need to configure bind interface command on dialpeers facing ITSP and dialpeers facing CUCM to use the right interfaces using the command 'voice-class sip bind control source-interface x/x'
08-11-2015 10:14 AM
along with what Chris suggest, Please collect the debug voice ccapi inout as well. Make a test to the number which is not working.
enable these debugs and post the same.
Br,
Nadeem
09-04-2017 05:49 AM
Hello
I have exactly the same problem and I wonder if you ever found a solution?
If so, I appricate to share the solution for this problem.
Peter
09-04-2017 05:58 AM
09-04-2017 06:45 AM
09-04-2017 07:25 AM
09-04-2017 08:38 AM
Hello Abhay
Find attached the traces for the following calls:
working call:
calling number: 0313067201
called number: 0319972357
not working call:
called number: 0316333231
Interesting is, that there is an Voicemail behind the called number of the not working call and it's only not working for some numbers.
Attached you find a snipset of the configuration as well.
Peter
09-04-2017 09:55 AM
09-05-2017 07:47 AM
Hello
As you mentioned in the previous post I applied the bind commands and the pass-thru on the CUBE.
Now I see no more the internal server error, but the caller has no ringbacktone.
For this I changed the SIP Rel1XX Options parameter from disabled to Send PRACK if 1XX contains SDP.
But it changed nothing, still no ringbacktone for certain dialed numbers.
Do you have an idea what to change?
Peter
09-05-2017 08:10 AM - edited 09-05-2017 08:11 AM
Try removing the below command and see what do you get then, as the interface has been bind. Check if the call still works or not and if it does and still there is no ringback tone, provide the debugs as provided earlier.
voice service voip
sip
no pass-thru content sdp
PS :- We have come to the point now where CUBE is not sending 500 internal server error anymore.
Keep this thread posted after making the changes.
Abhay
