03-31-2020 01:23 PM
I have the following call flow:
PSTN - CUBE - CUE
on call leg between provider and CUBE I have g711alaw with dtmf in band, on call leg between CUBE and CUE I have g711ulaw and dtmf relay sip notify configured.
The call connects and transcoder is being invoked for alaw to ulaw but DTMF is not being passed from PSTN to CUE.
I did packet capture and I see DTMF arriving as inband voice signals to CUBE, so it looks like it's issue on my end.
I have attached sh run, and debug ccsip messages. I really dont know why this would not work.
Appriciate any help.
radio-cme#sh dspfarm profile 1
Dspfarm Profile Configuration
Profile ID = 1, Service =Universal TRANSCODING, Resource ID = 1
Profile Service Mode : Non Secure
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : CUBE Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Total Number of Resources Configured : 16
Total Number of Resources Available : 16
Total Number of Resources Out of Service : 0
Total Number of Resources Active : 0
Codec Configuration: num_of_codecs:5
Codec : pass-through, Maximum Packetization Period : 0
Codec : g711ulaw, Maximum Packetization Period : 30
Codec : g711alaw, Maximum Packetization Period : 30
Codec : g729ar8, Maximum Packetization Period : 60
Codec : g729abr8, Maximum Packetization Period : 60
04-01-2020 01:10 AM - edited 04-01-2020 01:10 AM
Hi there,
According to the configs you have supplied, you have no DTMF relay settings configured on what looks like your inbound dial-peers (dial-peers 100 and 101).
Can you try adding the DTMF relay for rtp-nte on these dial-peers and test again please?
Good luck!
Scott
04-01-2020 01:33 AM
Hi Scott,
thanks for your reply. I have tried that but the result is the same.
Dont think it made a difference, debugs look exactly the same.
BR,
Matija
04-02-2020 01:15 AM
Hi Matija,
You could try adding sip-notify to the two incoming dial-peers in addition to the rtp-nte.
If that doesn't work, consider some of the advice in this thread:
https://community.cisco.com/t5/ip-telephony-and-phones/cue-dtmf-issue/td-p/1987789
Scott
04-02-2020 02:09 AM
Hi Scott, yeah I tried that, and I saw this thread before, unfortunately none of the suggestions there works for me.
The problem in that thread turned out to be with provider, I would also like it if the problem is with provider, however when I do tcp dump on CUBE, on inbound interface to which provider is connected, I see digits arrive in RTP stream. So provider is sending in band DTMF to CUBE. From that I conclude CUBE is not reading those and transcoding them to sip notify and sending to CUE.
thanks for your help.
04-20-2020 12:42 PM
04-20-2020 10:50 PM
Hi Scott, I solved the issue by configuring Cisco Unity express for rtp nte instead of sip notify. I don't have any experience with CUE, so at first I didn't know this is possible, but then I find out in some community post that it should support both, and I just changed it in CLI. I think CUBE can't transcode from in band to out of band like sip info or sip notify.
Matija
04-21-2020 12:44 AM
