CUBE and CUCME on same box?
desgreene
I can't seem to find this definitively documented anywhere.
Is it possible to run both CUBE and CME on the same 29xx ISR?
If yes, can anybody point me to example configurations?
Thanks.
Chris Deren
Yes, it is supported. No special configuration needed, regular CME config and CUBE config. You can search this forum for some examples.
HTH,
Chris
Chris Deren
HTH,
Chris
Thanks for the confirmation Chris.
Des
