09-25-2018 12:56 AM - edited 03-17-2019 01:31 PM
We have an ISR4331 gateway and I understand that from IOS XE 16.7.1 we can have CUBE and SIP SRST.
I am looking for some examples, since I am not that familiar with SIP multi-tenanancy.
Does someone have some basic examples for CUBE co-configured with SIP SRST?
JH
09-25-2018 08:01 AM - edited 09-25-2018 08:02 AM
09-25-2018 08:34 AM
Thanks for the reply
I need one SIP trunk and SIP SRST
I configure the one trunk with "voice class tenant 1" and then the normal SIP SRST?
JH
09-25-2018 08:40 AM
09-25-2018 08:43 AM
I read somewhere that the co-install of CUBE and SRST needed this confi
So, it is just upgrading to IOS XE 16.7.1 or higher and then configure CUBE and SRST
I shall do that
Thanks!
Jan
09-25-2018 08:47 AM
09-25-2018 09:08 AM
Jan is correct on this one, it's not mandatory, but it is recommended to use voice class tenant to avoid conflicting configuration from what you need for SRST, and what the ITSP might need.
Review this Live session
SIP Trunking with Cisco Unified Border Element (CUBE/vCUBE) Enterprise and SRST Co-location - BRKCOL-2125
09-30-2018 02:27 AM
Thank you all for your help
I shall follow the advice from Jaime and configure the voice class tenat
Jan
08-27-2019 02:59 AM
we use isr4331 and sip-trunk. now we want to realize colocation sip-trunk with srst. did you finished your configuration , can you share your experiences ?
thanks
regards
Alex
