02-01-2011 06:29 PM - edited 03-16-2019 03:12 AM
I was testing codec translation feature of CUBE, but couldn't get it worked.
Here's the call flow:
IP Phone (5001) --> CUCM (as OGW) --> Gatekeeper (HQ-RTR) --> CUBE (HQ-RTR) --> CME (BR2-RTR, as TGW) --> IP Phone (3001).
The symptom was: 5001 can ring 3001. When 3001 answers, 5001 keeps playing ring-back for a couple seconds, then the call got disconnected. "debug voip ccapi inout" shows the cause code was 47 (resource not available).
On CUBE, the incoming call leg was G.729, outgoing call leg was G.711. I configured xcoder on CUBE.
When the call was ringing, I saw this on HQ-RTR:
HQ-RTR#sh gatek call
Total number of active calls = 2.
GATEKEEPER CALL INFO
LocalCallID Age(secs) BW
21-130 2 16(Kbps)
Endpt(s): Alias E.164Addr
src EP: gk-trunk_2 5001
CallSignalAddr Port RASSignalAddr Port
10.10.210.11 1720 10.10.210.11 32799
dst EP: HQ-RTR 3001
10.10.200.3 1720 10.10.200.3 61544
22-130 2 128(Kbps)
src EP: HQ-RTR 5001
dst EP: BR2-RTR 3001
10.10.110.3 1720 10.10.110.3 63446
Xcoder was registered to HQ-RTR:
HQ-RTR#sh sdspfarm units
mtp-1 Device:hq-xcoder TCP socket:[1] REGISTERED in SCCP ver 17/10
actual_stream:6 max_stream 6 IP:10.10.200.3 20930 MTP Dixieland keepalive 185
Supported codec:
G711Ulaw
G711Alaw
G729
G729a
G729b
G729ab
max-mtps:1, max-streams:6, alloc-streams:6, act-streams:0
Attached are the config file for HQ-RTR and BR2-RTR.
Thanks!
Solved! Go to Solution.
02-02-2011 05:42 AM
the config looks fine to me, have to unticked 'wait for far end h.245 terminal
capability set' under the trunk?
02-02-2011 05:42 AM
02-02-2011 06:38 AM
That was it!
Any further documents explain why this needs to be unchecked?
Thank you again!
Michael
02-02-2011 06:47 AM
glad to be of help.
Check this link out for more information, its basically a stale mate between cucm and cme as they are both waiting for the h245 phase of the call setup which occurs after the call is actually setup, the calls then just times out.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/video.html#wp1046354
hth
