I'm using CUCM 9.1.2 and am sending external calls via a CUBE through a SIP trunk to our carrier. All normals calls are sent with a + but any call forwarded calls are sent with ++. Below is an example
calling number 1-111-111-1111 (from outside) calls 1-222-222-2222 (internal) which is then forwarded to 1-333-333-3333 (external)
The CUBE shows the call from ++11111111111 (Calling) to 13333333333 (Called) being sent to trough the trunk.
If 1-222-222-2222 calls normally to 333-333-3333 the call is sent as follows
+12222222222 (Calling) to 13333333333 (Called)
How do I get the additional + removed from call forwards?
