06-13-2016 03:47 AM - edited 03-17-2019 07:13 AM
HI ,
I need to configure CUBE with SIP as primary & BRI as backup. Both connections goes to same ITSP. How do I fail-over to BRI, when the SIP failure & recover back to SIP when the SIP comes up? CUBE also has SRST.
06-13-2016 05:36 AM
In the CUCM, I will create a RG with Top Down Configuration, and inside with two SIP Trunks, one to the CUBE on Top and another to GW BRI on the bottom.
In the CUBE I will put sip-options to sense when the ISTP goes down.
06-13-2016 07:23 AM
in Cube, assign higher preference to SIP PSTN dial peer than BRI dial peer.
06-13-2016 08:33 AM
In my opinion, CUCM changes are not necessary. As Mohit stated below, you want to have your dial-peers setup with preferences, and you can test that the failover works by shutting down the primary VOIP (SIP) dial-peer. Here's an example of what you would need:
dial-peer voice 1 voip
description ITSP-SIP-TRUNK-PRIMARY
preference 1
destination-pattern 1........
session protocol sipv2
session target xxxxxxxxxxxxxx
voice-class codec X
dtmf-relay rtp-nte
no vad
dial-peer voice 2 pots
description FAILOVER-BRI
preference 2
destination-pattern 1..........
port 0/0/0
forward-digits 10
I hope that helps.
FG
06-14-2016 03:09 AM
HI FG,
Do i need to configure sip-options to sense the ITSP status?
