Beginner
Cube configuration
Hii,
I have Cucm 10.5  and 2x2921 and 1x2801 and I receive a request from our providers that they give a SIP connections with our locations. My questions is if i can activate the Cube on 2801 and to test a call from my locations to out said (PSTN). Can you help pls with how to connect the providers to my routers and what are the settings to do.
I have internal extensions start with 1000 until 4500
This is the steps in order to activate the CUBE:
- trunk to cube from cucm10.5
- create a Route Pattern ( 0xxxx) to forward the call to CUBE
- activate the cube:         voice service voip
                                                Allow-connections sip to sip
                                                Allow-connections sip to h323
                                                Allow-connections h323 to h323
Ip addres trust list: ip of Cucm / ip of PSTN
Dial-peer voice 1 voip
                Incoming called-numer .#
                No vad
Dial-peer voice 2 voip
                Destination-pattern 00xxxx
                Session target ip PSTN
Dial-peer voice 10 voip
                Destination-pattern 2000
                Session target ip Cucm
                Session protocol sipv2
Guys thanks a lot for any steps informations
1 ACCEPTED SOLUTION
Engager
Yes, this is possible but
Yes, this is possible but never recommended to connect CUCM directly to provider b/c of security reasons.
Moreover if your provider needs SIP registration, CUBE is must as CUCM doesn't support SIP registration.
5 REPLIES 5
Highlighted
Hi,You can check the
You can check the following config example for CUBE
http://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/117300-configure-cube-00.html
Manish
Beginner
hey manis, Can y help pls wit
hey manis,
Can y help pls wit the proper steps to conect with provider. I want to test with 2801, it's able to work like a Cube this router?
I don't now how to connect at Physical  layer the provider with my router and what is the setup for all my range phone nr.
Cisco 2800 Series Integrated
Cisco 2800 Series Integrated Services Routers can provide CUBE functionality.
The following document cover all the configuration needed on cucm and gateway configured as CUBE
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/99863-cube-config.html
The destionation-pattern in the dial-peers should be configured as per the phone number range in your setup.
Manish
Beginner
Hey, They say that we can
Hey,
They say that we can connect with the provider router directly from Calll Manger without Cube, this is possible?
And if yes how?
Engager
Content for Community-Ad
August's Community Spotlight Awards
