07-11-2016 11:30 PM - edited 03-17-2019 07:30 AM
Dear Expert,
I need help
I have configured SIP trunk to my cucm and iptsp service provider. When I place a outgoing call my router is restart automatically.
kafi
07-12-2016 12:25 AM
Hi Kafi,
Can you make sure that all debugging is off on the router, check if the router has the required memory installed and working.
Manish
07-12-2016 08:05 PM
Thanks For your Reply
I think I am missing something. My router place a call from my ip phone to my mobile phone but there is no dial tone and when I receive this call I can't hear anything.
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
enable password cisco
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
voice service voip
ip address trusted list
ipv4 172.16.145.3
ipv4 182.16.159.6
address-hiding
mode border-element
media flow-around
allow-connections sip to sip
no supplementary-service sip refer
no supplementary-service sip handle-replaces
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
sip
session refresh
early-offer forced
no silent-discard untrusted
midcall-signaling passthru
privacy-policy passthru
voice class codec 1
codec preference 2 g711ulaw
codec preference 1 g711alaw
interface GigabitEthernet0/0
description ### IPTSP-WAN ###
ip address 172.17.5.250 255.255.255.248
duplex auto
speed auto
interface GigabitEthernet0/1
description ### LAN ###
ip address 172.16.128.7 255.255.192.0
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/3
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.17.5.249
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
destination-pattern 9613400400
session protocol sipv2
session target ipv4:172.16.145.3
voice-class codec 1
voice-class sip early-offer forced
dtmf-relay rtp-nte
no vad
dial-peer voice 10 voip
destination-pattern 01959700860
session target sip-server
voice-class codec 1
dtmf-relay rtp-nte
no vad
sip-ua
registrar ipv4:182.16.159.6 expires 3600
sip-server ipv4:182.16.159.6:5060
kafi
