CUBE configuration
MD KAFINUZZAMAN
Dear Expert,
I need help
I have configured SIP trunk to my cucm and iptsp service provider. When I place a outgoing call my router is restart automatically.
kafi
Manish Gogna
Hi Kafi,
Can you make sure that all debugging is off on the router, check if the router has the required memory installed and working.
Manish
Thanks For your Reply
I think I am missing something. My router place a call from my ip phone to my mobile phone but there is no dial tone and when I receive this call I can't hear anything.
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
logging buffered 51200 warnings
enable password cisco
no aaa new-model
bsd-client server url https://cloudsso.cisco.com/as/token.oauth2
voice service voip
 ip address trusted list
  ipv4 172.16.145.3
  ipv4 182.16.159.6
 address-hiding
 mode border-element
 media flow-around
 allow-connections sip to sip
 no supplementary-service sip refer
 no supplementary-service sip handle-replaces
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
 sip
  session refresh
  early-offer forced
  no silent-discard untrusted
  midcall-signaling passthru
  privacy-policy passthru
voice class codec 1
 codec preference 2 g711ulaw
codec preference 1 g711alaw
interface GigabitEthernet0/0
 description ### IPTSP-WAN ###
 ip address 172.17.5.250 255.255.255.248
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description ### LAN ###
ip address 172.16.128.7 255.255.192.0
 duplex auto
 speed auto
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
interface GigabitEthernet0/3
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 172.17.5.249
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
 destination-pattern 9613400400
 session protocol sipv2
 session target ipv4:172.16.145.3
 voice-class codec 1
 voice-class sip early-offer forced
 dtmf-relay rtp-nte
 no vad
dial-peer voice 10 voip
 destination-pattern 01959700860
 session target sip-server
 voice-class codec 1
 dtmf-relay rtp-nte
 no vad
sip-ua
 registrar ipv4:182.16.159.6 expires 3600
 sip-server ipv4:182.16.159.6:5060
kafi
