CUBE Destination Dial peer group configuration
Iptelephonysaxo
Hi all,
Can some one help me with the dial-peer config that i am goffing up on my new cube setup.
 Running config:-
voice-card 0
dspfarm
dsp services dspfarm
no voice hunt b-cap-unauthorized
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
ipv4 10.165.XX.XX 255.255.255.255
ipv4 10.70.XX.XX 255.255.255.255
cpa timing live-person 2501
cpa timing term-tone 15500
cpa threshold active-signal 18db
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service sip refer
no supplementary-service sip handle-replaces
signaling forward rawmsg
fax protocol pass-through g711ulaw
h323
sip
header-passing
error-passthru
midcall-signaling passthru media-change
early-offer forced
voice class uri 2 sip
host ipv4:10.70.25.36
host ipv4:10.70.25.42
host ipv4:10.70.25.37
host ipv4:10.70.25.43
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
voice class sip-profiles 301
request INVITE sip-header From modify "<sip:(.*)@(.*)>" "<sip:(.*)@10.165.XX.XX>"
request INVITE sip-header From modify "<sip:(.*)@(.*)>" "<sip:4539774160@10.165.XX.XX>"
voice class server-group 1
ipv4 10.165.XX.XX port 5060 preference 1
description ***SIP SP SIP Trunk***
voice class server-group 2
ipv4 10.70.25.36 port 5060 preference 1
ipv4 10.70.25.42 port 5060 preference 2
ipv4 10.70.25.37 port 5060 preference 3
ipv4 10.70.25.43 port 5060 preference 4
description **inbound calls and Refer to CUCM**
voice iec syslog
vxml logging-tag
license udi pid CISCO2951/K9 sn FGL154312A2
hw-module pvdm 0/0
username 8ackd00r secret 5 $1$B/nI$3M3ObPpuQ498WmRuGmtX4.
username kiwi secret 5 $1$.LKw$gIJmnL1/5EhslkaMYpp3E1
redundancy
interface Loopback0
ip address 10.70.XX.XX255.255.255.255
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
description CONNECTED TO SWCXX.XX Ten 1/0/14
ip address 10.70.XX.XX 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.165.XX.XX 255.255.255.252
duplex auto
speed auto
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 10.70.1.1
ip tacacs source-interface Loopback0
ip access-list extended NTP-SERVERS
permit ip host 10.24.XX.XX any
logging trap debugging
logging facility local2
logging source-interface Loopback0
logging host 10.20.4.11
nls resp-timeout 1
tacacs server SYSISEAPL2-DK2
address ipv4 10.24.XX.XX
key 7 045632285C365F1D0A0B5603195835
timeout 15
single-connection
access-list 80 permit 10.24.XX.XX
access-list 90 permit 172.31.XX.XX
access-list 90 permit 10.0.XX.XX 0.255.255.255
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dspfarm profile 10 transcode
description CPA
codec g729abr8
codec g729ar8
codec g711alaw
codec g711ulaw
call-progress-analysis
maximum sessions 21
associate application CUBE
shutdown
dial-peer voice 1 voip
description ***CUCM to CUBE***
session protocol sipv2
session target sip-server
incoming called-number 8T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 2 voip
description ***CUBE to CUCM***
destination-pattern 4......$
session target ipv4:10.70.XX.XX
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 10 voip
description ***SP to CUBE***
incoming called-number 4T
dtmf-relay rtp-nte
codec g711ulaw
dial-peer voice 20 voip
description ***CUBE to SP***
destination-pattern 0T
session target ipv4:10.165.XX.XX
dtmf-relay rtp-nte
codec g711ulaw
sip-ua
credentials username +XXXXXXXXXX@ims.XXXX.in password 7 0235054304011D621D realm ims.XXXX.in
authentication username +XXXXXXXXXX@ims.XXXX.in password 7 097F4F11160205515A
retry invite 2
retry bye 2
retry cancel 2
registrar ipv4:10.165.XX.XX expires 60 auth-realm ims.XXXX.in
sip-server ipv4:10.165.XX.XX
connection-reuse
host-registrar
g729-annexb override
gatekeeper
shutdown
vstack
line con 0
exec-timeout 30 0
logging synchronous
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
access-class 90 in
exec-timeout 30 0
logging synchronous
transport input ssh
line vty 5 15
access-class 90 in
exec-timeout 30 0
logging synchronous
transport input ssh
scheduler allocate 20000 1000
ntp source Loopback0
ntp access-group peer NTP-SERVERS
ntp server 10.24.XX.XX
ntp server pnpntpserver.XX.XX
end
Debug file is attached
6 Replies 6
You need to have incoming dialpeer to match your call and set your codec and dtmf at both incoming and outgoing dialpeers
Hi Mohammed,
Thanks for you reply.
i have made 4 dial peers 1,2 10 and 10
dialpeer 1 is for incoming calls from CUCM to cube
dialpeer 2 is from CUbe to CUCM
dialpeer 10 incoming calls from SP to CUBE
dialpeer 20 cube to SP.
Please let me know which one i am messing up.
configure this dialpeer and test
dial-peer voice 25 voip
incoming called-number .
dtmf-relay rtp-nte sip-kpml
no vad
codec g711ulaw
Still getting same error
ROV3.IN2#debug voip ccapi inout
voip ccapi inout debugging is on
ROV3.IN2#
Feb 28 05:27:19.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=07042121900, Called Number=07042121900, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=07042121900
Feb 28 05:27:19.368: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=07042121900, Expanded String=07042121900, Calling Number=07042121900T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 28 05:27:19.368: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=20 Is Matched
Result=Success(0) after DP_MATCH_DEST
Feb 28 05:27:19.368: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=07042121900, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
Feb 28 05:27:19.368: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=20
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=8912351, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Match Rule=DP_MATCH_ANSWER; Calling Number=8912351
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=, Expanded String=, Calling Number=8912351T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7265
Match Rule=DP_MATCH_ORIGINATE; Calling Number=8912351
Result=-1
Result=NO_MATCH(-1) After All Match Rules Attempt
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=-1
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@7896
Result=-1
Result=-1
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpAssociateIncomingPeerCore:
Calling Number=8912351, Called Number=07042121900, Voice-Interface=0x0,
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.70.25.42:5060
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpMatchPeertype:
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpMatchCore:
Result=-1
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpMatchPeertype:exit@7265
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:07042121900@10.70.3.10:5060
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:07042121900@10.70.3.10
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:8912351@10.70.25.42
Result=-1
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=07042121900
Feb 28 05:27:19.372: //-1/83001B000000/DPM/MatchNextPeer:
Result=Success(0); Incoming Dial-peer=25 Is Matched
Result=Success(0) after DP_MATCH_INCOMING_DNIS; Incoming Dial-peer=25
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpMatchSafModulePlugin:
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
Feb 28 05:27:19.372: //-1/83001B000000/DPM/dpAssociateIncomingPeerSPI:exit@7847
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/DPM/dpGetSIPUriProvisionBmp:
Tag=25
Result=0 Bitmap=0x0
Feb 28 05:27:19.372: //-1/83001B000000/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=8912351
----- ccCallInfo IE subfields -----
cisco-ani=sip:8912351@10.70.25.42
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=sip:07042121900@10.70.3.10:5060
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
Feb 28 05:27:19.372: //-1/83001B000000/CCAPI/cc_api_call_setup_ind_common:
Interface=0x14E0DF24, Call Info(
Calling Number=sip:8912351@10.70.25.42,(Calling Name=)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=sip:07042121900@10.70.3.10:5060(TON=Unknown, NPI=Unknown),
Calling Translated=FALSE, Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE,
Incoming Dial-peer=25, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=505
Feb 28 05:27:19.372: //-1/83001B000000/CCAPI/ccCheckClipClir:
In: Calling Number=sip:8912351@10.70.25.42(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Out: Calling Number=sip:8912351@10.70.25.42(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed)
Feb 28 05:27:19.372: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 28 05:27:19.372: :cc_get_feature_vsa malloc success
Feb 28 05:27:19.372: cc_get_feature_vsa count is 1
Feb 28 05:27:19.372: :FEATURE_VSA attributes are: feature_name:0,feature_time:328539208,feature_id:47
Feb 28 05:27:19.372: //505/83001B000000/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=(TON=Unknown, NPI=Unknown))
Feb 28 05:27:19.376: //505/83001B000000/CCAPI/cc_process_call_setup_ind:
Event=0x2C9D690
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 07042121900
Feb 28 05:27:19.376: //505/83001B000000/CCAPI/ccCallSetContext:
Context=0x367D538
>>>>CCAPI handed cid 505 with tag 25 to app "_ManagedAppProcess_Default"
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Result=-1
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7265
Result=-1
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@7896
Feb 28 05:27:19.376: //505/83001B000000/CCAPI/ccCallProceeding:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/CCAPI/ccGetMemPoolFromContainer:
mempool not found from usrContainer(35E6E98)
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/CCAPI/ccCreateMemPoolInContainer:
Mempool(12C78F4) created in usrContainer(35E6E98)
Feb 28 05:27:19.376: //-1/83001B000000/DPM/dpMatchPeersCore:
Calling Number=, Called Number=07042121900, Peer Info Type=DIALPEER_INFO_SPEECH
Feb 28 05:27:19.376: //-1/83001B000000/DPM/dpMatchCore:
Feb 28 05:27:19.376: //-1/83001B000000/DPM/MatchNextPeer:
Feb 28 05:27:19.376: //-1/83001B000000/DPM/dpMatchSafModulePlugin:
dialstring=07042121900, saf_enabled=0, saf_dndb_lookup=1, dp_result=0
Feb 28 05:27:19.376: //-1/83001B000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
Result=SUCCESS(0)
1: Dial-peer Tag=20
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 28 05:27:19.376: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
Calling Number=07042121900, Called Number=, Voice-Interface=0x0,
Match Rule=DP_MATCH_ANSWER; Calling Number=07042121900
Dial String=, Expanded String=, Calling Number=07042121900T
Result=-1
Match Rule=DP_MATCH_ORIGINATE; Calling Number=07042121900
Result=Success(0); Incoming Dial-peer=20 Is Matched
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=20
Result=-1
Result=SUCCESS(0)
1: Dial-peer Tag=20
Feb 28 05:27:19.380: //-1/83001B000000/DPM/dpMatchPeersCore:
Feb 28 05:27:19.380: //-1/83001B000000/DPM/dpMatchCore:
Feb 28 05:27:19.380: //-1/83001B000000/DPM/MatchNextPeer:
Feb 28 05:27:19.380: //-1/83001B000000/DPM/dpMatchSafModulePlugin:
Feb 28 05:27:19.380: //-1/83001B000000/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
Feb 28 05:27:19.380: //505/83001B000000/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=20, Params=0x3679478, Progress Indication=NULL(0)
Feb 28 05:27:19.380: //505/83001B000000/CCAPI/ccCheckClipClir:
Destination Pattern=0T, Called Number=07042121900, Digit Strip=FALSE
Calling Number=sip:8912351@10.70.25.42(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=07042121900(TON=Unknown, NPI=Unknown),
Redirect Number=, Display Info=Vaibhav Sharma - 8912351
Account Number=8912351, Final Destination Flag=TRUE,
Guid=83001B00-0001-0000-0000-B1102A19460A, Outgoing Dial-peer=20
Feb 28 05:27:19.380: //505/83001B000000/CCAPI/cc_api_display_ie_subfields:
ccCallSetupRequest:
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=1
dest=07042121900
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=0
cisco-rdnplan=0
cisco-rdnpi=-1
cisco-rdnsi=-1
Feb 28 05:27:19.380: //505/83001B000000/CCAPI/ccIFCallSetupRequestPrivate:
Interface=0x14E0DF24, Interface Type=3, Destination=, Mode=0x0,
Call Params(Calling Number=sip:8912351@10.70.25.42,(Calling Name=Vaibhav Sharma - 8912351)(TON=Unknown, NPI=Unknown, Screening=User, Passed, Presentation=Allowed),
Called Number=07042121900(TON=Unknown, NPI=Unknown), Calling Translated=FALSE,
Subscriber Type Str=Unknown, FinalDestinationFlag=TRUE, Outgoing Dial-peer=20, Call Count On=FALSE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, tg_label_flag=0, Application Call Id=)
Feb 28 05:27:19.380: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
Feb 28 05:27:19.380: :cc_get_feature_vsa malloc success
Feb 28 05:27:19.380: cc_get_feature_vsa count is 2
Feb 28 05:27:19.380: :FEATURE_VSA attributes are: feature_name:0,feature_time:328538984,feature_id:48
Feb 28 05:27:19.380: //506/83001B000000/CCAPI/ccIFCallSetupRequestPrivate:
SPI Call Setup Request Is Success; Interface Type=3, FlowMode=1
Feb 28 05:27:19.380: //506/83001B000000/CCAPI/ccCallSetContext:
Context=0x3679428
Feb 28 05:27:19.380: //505/83001B000000/CCAPI/ccSaveDialpeerTag:
Feb 28 05:27:19.380: //506/83001B000000/CCAPI/cc_api_call_proceeding:
Interface=0x14E0DF24, Progress Indication=NULL(0)
Feb 28 05:27:19.380: //506/xxxxxxxxxxxx/CCAPI/cc_api_get_xcode_stream:
Feb 28 05:27:19.380: cc_api_get_xcode_stream : 4987
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
1: Dial-peer Tag=20
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Result=-1
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:exit@7265
Result=-1
Feb 28 05:27:19.384: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeer:exit@7896
Result=-1
Result=-1
Feb 28 05:27:19.384: //-1/83001B000000/DPM/dpAssociateIncomingPeerCore:
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.165.10.250:5060
Feb 28 05:27:19.384: //-1/83001B000000/DPM/dpMatchPeertype:
Feb 28 05:27:19.384: //-1/83001B000000/DPM/dpMatchCore:
Result=-1
Feb 28 05:27:19.384: //-1/83001B000000/DPM/dpMatchPeertype:exit@7265
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:07042121900@10.165.10.250:5060
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:07042121900@10.165.10.250
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:8912351@10.165.10.249
Result=-1
Feb 28 05:27:19.384: //-1/83001B000000/DPM/MatchNextPeer:
ROV3.IN2#Disposition=0, Interface=0x14E0DF24, Tag=0x0, Call Id=505,
Call Entry(Disconnect Cause=41, Voice Class Cause Code=0, Retry Count=0)
Feb 28 05:27:19.396: //505/83001B000000/CCAPI/cc_api_call_disconnect_done:
Call Disconnect Event Sent
Feb 28 05:27:19.396: //-1/xxxxxxxxxxxx/CCAPI/cc_free_feature_vsa:
Feb 28 05:27:19.396: :cc_free_feature_vsa freeing 13951C40
Thanks again for reply. however it did not help
attached are the new debugs
get 'debug ccsip mess' only.
