CUBE DNS SRV Record for H323 Trunks to CUCM
DaveBarilla
Is it possible to use a DNS SRV records in CUBE for H323 Trunk redundancy?
I have seen it posted in other discussions that DNS SRV are used for VCS H323 trunks and endpoint registration. The service format for call signalling is as follows:
_h323cs._tcp.company.com. srv 50 0 1720 trunk1.company.com.
_h323cs._tcp.company.com. srv 60 0 1720 trunk2.company.com.
So my theory is that I should be able to configure the same service record on CUBE using IP Host commands and then using the dns srv as the session target in the dial-peer. Much like one would do with a SIP trunk.
Config example:
ip host trunk1.company.com A.B.C.1
ip host trunk2.company.com A.B.C.2
Ip host _h323cs._tcp.cucm.company.com. srv 50 0 1720 trunk1.company.com.
Ip host _h323cs._tcp.cucm.company.com. srv 60 0 1720 trunk2.company.com.
dial-peer voice 100 voip
 tone ringback alert-no-PI
 destination-pattern .........
 session target dns:cucm.company.com
 voice-class codec 1
 voice-class h323 1
 dtmf-relay cisco-rtp h245-alphanumeric
Can anyone confirm weather this will work? Is it supported?
Dave
Rajan
Hi Dave,
I have configured the same way while testing Expressway in lab. Configured DNS SRV records in the Voice Gateway and pointed its IP as the DNS server on the required PC. It was working.
You need to make sure that if any other device which needs to resolve this will have this CUBE IP used as its DNS server.
Rajan
Pls rate all useful posts
Hi Rajan,
Thank you for the quick response. I'm wondering will this work for trunks originating from the CUBE? My setup is PSTN PRIs in, H323 Trunk out to CUCM
PSTN-----PRI--->CUBE---H323--->CUCM
Dave
Hi Dave,
It should ideally work as long as you enable DNS on the CUBE.
Rajan
Chris Deren
What version is your IOS as if it's relatively newer you can just use "voice class server-group" feature  preferred over SRV.
