ā04-22-2018
09:11 AM
- last edited on
ā03-25-2019
08:45 PM
by
ciscomoderator
hello,
we have a sip trunk from ITSP
the authentication is only by IP
we have a cucm >>>> cube >>>>>ITSP
the cube configuration as following:
version 15.4
service password-encryption
no service password-recovery
hostname XXXXXX
boot-start-marker
boot-end-marker
aqm-register-fnf
enable secret 5 XXXXXXXX
enable password 7 XXXXXXXX
no aaa new-model
ip vrf vrf1
ip domain name XXXXXX.local
ip cef
no ipv6 cef
voice-card 0
voice service voip
ip address trusted list
ipv4 10.123.101.162
ipv4 192.168.1.10
ipv4 192.168.1.21
ipv4 10.198.13.86
ipv4 10.198.13.85
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service media-renegotiate
sip
min-se 86400 session-expires 86400
header-passing
registrar server
early-offer forced
midcall-signaling passthru
voice class uri 200 sip
host ipv4:10.123.101.162
voice class codec 1
codec preference 2 clear-channel
codec preference 3 g711alaw
codec preference 4 g711ulaw
codec preference 5 g723r53
codec preference 6 g723r63
codec preference 7 g726r16
codec preference 8 g726r24
codec preference 9 g726r32
codec preference 10 g728
codec preference 11 g729br8
codec preference 12 g729r8
codec preference 13 ilbc
voice translation-rule 1
rule 1 /0212022..../ /8999999/
rule 2 /212022..../ /8999999/
rule 3 /2022..../ /8999999/
voice translation-rule 2
rule 1 /^9/ //
voice translation-profile 100
translate called 1
voice translation-profile OUT
translate called 2
license udi pid C3900-SPE150/K9 sn XXXXXX
license boot module c3900 technology-package uck9
archive
log config
logging enable
username xxx
redundancy
interface GigabitEthernet0/0.1
encapsulation dot1Q 11
ip address 192.168.1.10 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/2.2
encapsulation dot1Q 900
ip address 10.198.13.86 255.255.255.252
ip forward-protocol nd
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 2 voip
description cube to cucm
destination-pattern [1,8].T
session protocol sipv2
session target ipv4:192.168.1.21
voice-class codec 1
dtmf-relay h245-alphanumeric rtp-nte
dial-peer voice 200 voip
description pstn to cube
translation-profile incoming 100
session transport udp
voice-class codec 1
dtmf-relay rtp-nte sip-kpml sip-notify
fax protocol pass-through g711alaw
no vad
dial-peer voice 250 voip
description cube tp pstn
translation-profile outgoing OUT
destination-pattern 9T
session target ipv4:10.123.101.162
voice-class codec 1
voice-class sip options-keepalive up-interval 100 down-interval 50 retry 6
no vad
dial-peer voice 321 voip
translation-profile outgoing 100
destination-pattern 2022....
no vad
sip-ua
retry invite 3
retry response 3
retry bye 3
retry cancel 3
retry rel1xx 3
timers connect 100
timers connection aging 30
registrar ipv4:10.123.101.162 expires 3600
host-registrar
gatekeeper
shutdown
telephony-service
max-ephones 20
max-dn 20
ip source-address 192.168.1.10 port 2000
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 20
number 20220000
ephone 1
device-security-mode none
mac-address D8CB.8AFC.0B70
button 2:20
when I call from the phone registered on cme to cucm its OK but trying ITSP no chance
debug ccsip message output is as follows:
*Apr 22 15:34:27.388: //1719/000000000000/SIP/Msg/ccsipDisplayMsg:
Sent:
OPTIONS sip:10.123.101.162:5060 SIP/2.0
Via: SIP/2.0/UDP 10.198.13.86:5060;branch=z9hG4bK6511DA
To: <sip:10.123.101.162>
Date: Sun, 22 Apr 2018 15:34:27 GMT
Call-ID: 79EF5266-457911E8-89B38B84-9C99BF5E@10.198.13.86
User-Agent: Cisco-SIPGateway/IOS-15.4.1.T3
Max-Forwards: 70
CSeq: 101 OPTIONS
Contact: <sip:10.198.13.86:5060>
Content-Length: 0
*Apr 22 15:34:32.748: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.123.101.162:5060 SIP/2.0
Via: SIP/2.0/UDP 10.198.13.86:5060;branch=z9hG4bK6521FAA
From: <sip:20220000@10.123.101.162>;tag=1B0EAF64-2246
To: <sip:20220000@10.123.101.162>
Date: Sun, 22 Apr 2018 15:34:32 GMT
Call-ID: 9FF20FD3-456A11E8-88BF8B84-9C99BF5E
Max-Forwards: 70
Timestamp: 1524411272
CSeq: 34 REGISTER
Contact: <sip:20220000@10.198.13.86:5060>
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:33.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:33 GMT
Max-Forwards: 70
Timestamp: 1524411273
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:34.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:34 GMT
Max-Forwards: 70
Timestamp: 1524411274
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:36.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:36 GMT
Max-Forwards: 70
Timestamp: 1524411276
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
ZH-TCI-Floor3-3945-R1#
*Apr 22 15:34:40.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:40 GMT
Max-Forwards: 70
Timestamp: 1524411280
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:20225858@10.198.13.86:5060;user=phone SIP/2.0
Via: SIP/2.0/UDP 10.123.101.162:5060;branch=z9hG4bKvp4ubervx4xxwuppr44ubpttt;Role=3;Hpt=8ec8_16
Record-Route: <sip:10.123.101.162:5060;transport=udp;lr;Hpt=8ec8_16;CxtId=4;TRC=ffffffff-ffffffff;X-HwB2bUaCookie=300>
Call-ID: isbcv222jmm6ejm8n4ssteenqz6nne6qq10t@SoftX3000
From: <sip:9128574118@10.198.13.86;user=phone>;tag=vtn11qv2-CC-31
To: <sip:20225858@10.198.13.86;user=phone>
CSeq: 1 INVITE
Allow: INVITE,ACK,OPTIONS,BYE,CANCEL,REGISTER,INFO,PRACK,SUBSCRIBE,NOTIFY,UPDATE,MESSAGE,REFER
Contact: <sip:9128574118@10.123.101.162:5060;transport=udp;Hpt=8ec8_16;CxtId=4;TRC=ffffffff-ffffffff>
Max-Forwards: 69
Supported: 100rel,timer
User-Agent: Huawei SoftX3000 V300R010
Session-Expires: 300
Min-SE: 90
Content-Length: 271
Content-Type: application/sdp
v=0
o=- 16260238 16260238 IN IP4 10.123.101.162
s=SBC call
c=IN IP4 10.123.101.162
t=0 0
m=audio 11334 RTP/AVP 8 3 97 96
a=rtpmap:8 PCMA/8000
a=rtpmap:3 GSM/8000
a=rtpmap:97 telephone-event/8000
a=rtpmap:96 RED/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
Calling Number=20225858, Called Number=20225858, Peer Info Type=DIALPEER_INFO_SPEECH
Match Rule=DP_MATCH_DEST; Called Number=20225858
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
Dial String=20225858, Expanded String=20225858, Calling Number=20225858T
Timeout=TRUE, Is Incoming=FALSE, Peer Info Type=DIALPEER_INFO_SPEECH
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
Result=Success(0); Outgoing Dial-peer=321 Is Matched
Result=Success(0) after DP_MATCH_DEST
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
dialstring=20225858, saf_enabled=1, saf_dndb_lookup=1, dp_result=0
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
List of Matched Outgoing Dial-peer(s):
1: Dial-peer Tag=321
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
Calling Number=9128574118, Called Number=, Voice-Interface=0x0,
Timeout=TRUE, Peer Encap Type=ENCAP_VOIP, Peer Search Type=PEER_TYPE_VOICE,
Match Rule=DP_MATCH_ANSWER; Calling Number=9128574118
*Apr 22 15:34:41.112: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Is Incoming=TRUE, Number Expansion=FALSE
Dial String=, Expanded String=, Calling Number=9128574118T
Timeout=TRUE, Is Incoming=TRUE, Peer Info Type=DIALPEER_INFO_SPEECH
Result=-1
Match Rule=DP_MATCH_ORIGINATE; Calling Number=9128574118
Result=Success(0); Incoming Dial-peer=250 Is Matched
Result=Success(0) after DP_MATCH_ORIGINATE; Incoming Dial-peer=250
dialstring=NULL, saf_enabled=0, saf_dndb_lookup=0, dp_result=0
*Apr 22 15:34:41.112: //-1/821D70AB89B4/DPM/dpAssociateIncomingPeerCore:
Calling Number=9128574118, Called Number=20225858, Voice-Interface=0x0,
Match Rule=DP_MATCH_VIA_URI; URI=sip:10.123.101.162:5060
*Apr 22 15:34:41.112: //-1/821D70AB89B4/DPM/dpMatchPeertype:
*Apr 22 15:34:41.112: //-1/821D70AB89B4/DPM/dpMatchCore:
Result=-1
Match Rule=DP_MATCH_REQUEST_URI; URI=sip:20225858@10.198.13.86:5060;user=phone
Result=-1
Match Rule=DP_MATCH_TO_URI; URI=sip:20225858@10.198.13.86;user=phone
Result=-1
Match Rule=DP_MATCH_FROM_URI; URI=sip:9128574118@10.198.13.86;user=phone
Result=-1
Match Rule=DP_MATCH_INCOMING_DNIS; Called Number=20225858
Result=-1
Result=-1
*Apr 22 15:34:41.112: //-1/821D70AB89B4/DPM/MatchNextPeer:
*Apr 22 15:34:41.112: //-1/821D70AB89B4/DPM/dpMatchSafModulePlugin:
Sent:
SIP/2.0 422 Session Timer too small
To: <sip:20225858@10.198.13.86;user=phone>;tag=1B0ED010-20A6
Date: Sun, 22 Apr 2018 15:34:41 GMT
CSeq: 1 INVITE
Allow-Events: kpml, telephone-event
Min-SE: 86400
Server: Cisco-SIPGateway/IOS-15.4.1.T3
Content-Length: 0
*Apr 22 15:34:41.212: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:41.412: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:41.608: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 69
Min-SE: 90
Content-Length: 271
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
Sent:
CSeq: 1 INVITE
Min-SE: 86400
Content-Length: 0
*Apr 22 15:34:41.812: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:42.604: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 69
Min-SE: 90
Content-Length: 271
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
Sent:
Date: Sun, 22 Apr 2018 15:34:42 GMT
CSeq: 1 INVITE
Min-SE: 86400
Content-Length: 0
*Apr 22 15:34:44.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:44 GMT
Max-Forwards: 70
Timestamp: 1524411284
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 69
Min-SE: 90
Content-Length: 271
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:44.608: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Result=-1
*Apr 22 15:34:44.608: //-1/8432E24189B5/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:44.608: //-1/8432E24189B5/DPM/dpMatchPeertype:
*Apr 22 15:34:44.608: //-1/8432E24189B5/DPM/dpMatchCore:
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
*Apr 22 15:34:44.608: //-1/8432E24189B5/DPM/MatchNextPeer:
*Apr 22 15:34:44.608: //-1/8432E24189B5/DPM/dpMatchSafModulePlugin:
Sent:
To: <sip:20225858@10.198.13.86;user=phone>;tag=1B0EDDB8-108F
CSeq: 1 INVITE
Min-SE: 86400
Content-Length: 0
*Apr 22 15:34:44.708: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:44.908: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:45.308: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:48.248: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Date: Sun, 22 Apr 2018 15:34:48 GMT
Max-Forwards: 70
Timestamp: 1524411288
CSeq: 34 REGISTER
Expires: 3600
Supported: path
Content-Length: 0
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 69
Min-SE: 90
Content-Length: 271
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:48.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Result=-1
*Apr 22 15:34:48.604: //-1/8694A01989B6/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:48.604: //-1/8694A01989B6/DPM/dpMatchPeertype:
*Apr 22 15:34:48.604: //-1/8694A01989B6/DPM/dpMatchCore:
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
*Apr 22 15:34:48.604: //-1/8694A01989B6/DPM/MatchNextPeer:
*Apr 22 15:34:48.604: //-1/8694A01989B6/DPM/dpMatchSafModulePlugin:
Sent:
To: <sip:20225858@10.198.13.86;user=phone>;tag=1B0EED54-10AD
CSeq: 1 INVITE
Min-SE: 86400
Content-Length: 0
*Apr 22 15:34:48.704: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:48.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:49.304: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
CSeq: 1 INVITE
Max-Forwards: 69
Min-SE: 90
Content-Length: 271
v=0
s=SBC call
t=0 0
a=rtpmap:3 GSM/8000
a=ptime:20
a=fmtp:97 0-15
a=fmtp:96 97/97
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpMatchCore:
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/MatchNextPeer:
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
Result=SUCCESS(0)
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:56.604: //-1/xxxxxxxxxxxx/DPM/dpMatchPeertype:
Result=-1
*Apr 22 15:34:56.604: //-1/8B59541989B7/DPM/dpAssociateIncomingPeerCore:
*Apr 22 15:34:56.604: //-1/8B59541989B7/DPM/dpMatchPeertype:
*Apr 22 15:34:56.604: //-1/8B59541989B7/DPM/dpMatchCore:
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
Result=-1
*Apr 22 15:34:56.604: //-1/8B59541989B7/DPM/MatchNextPeer:
*Apr 22 15:34:56.604: //-1/8B59541989B7/DPM/dpMatchSafModulePlugin:
Sent:
To: <sip:20225858@10.198.13.86;user=phone>;tag=1B0F0C94-263B
Date: Sun, 22 Apr 2018 15:34:56 GMT
CSeq: 1 INVITE
Min-SE: 86400
Content-Length: 0
*Apr 22 15:34:56.704: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:56.904: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
*Apr 22 15:34:57.304: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Min-SE: 86400
CSeq: 1 INVITE
Content-Length: 0
please help asap
ā04-23-2018 08:13 PM
First - You should update your publication and attach a txt with the config and another with the debug - having everything on the original post makes harder to read your problem.
Answering your question - the problem seems pretty obvious, from the debug:
The router is receiving an INVITE message with "Session-Expires: 300" usually this is 30mins (never seen it less than 15mins) but it is receiving a value of 5mins and therefore rejecting the call with "SIP/2.0 422 Session Timer too small"
Make sure the expiration value match between CUCM, CUBE and ITSP - I will recommend to increase it to 15mins.
Rolando A. Valenzuela.
ā04-28-2018 02:20 AM
ā04-24-2018 05:28 AM
sip
Why do you have such a high session expiry ? Lower it down to something that your ITSP supports and likes. The CUBE sending 422 is perfectly fine and per RFC the UAC should send another INVITE with the correct SE timer that has been advertised by UAS in 422 but the ITSP usually treat 422 as a disconnect/transaction completed state. Their boxes initiate a new transaction every time and the timer will be as it is.
So either talk to your ITSP or just use the value that they are sending in the INVITE i.e. "Min-SE: 90" which is a bit low IMO.
ā04-29-2018 01:38 AM
it worked with the min-se 300 value
we can not recommend any value to it's its not good but it solved the problem
