06-12-2018 06:04 AM - edited 03-17-2019 12:59 PM
We have a CUBE and we have a problem when we receive an INVITE the CUBE responds with error 400 Bad Request
When I did a "debug ccsip all" It seems the CUBE has problems with some options in the SDP. The SDP has these two options:
b=RS:375
b=RR:1125
In the debug there is the line:
/SIP/Info/sipSPIProcessDiversionHeader: No diversion headers recvd from app container SIP: Error: BW Modifier type unsupported (RS)
How can we change the CUBE to ignore these bandwidth modifiers?
JH
Solved! Go to Solution.
06-12-2018 07:59 AM
06-12-2018 06:42 AM
Hi @j.huizinga
Do you have configured CAC (call admission control) on your CUBE?
06-12-2018 06:51 AM
No CAC configured at all, no where. Not needed.
I would like the CUBE to ignore these SDP options
Jan
06-12-2018 06:57 AM - edited 06-12-2018 06:58 AM
Ok @j.huizinga
Perhaps you don't need that at all but as I concerned CAC config on my CUBE gave me that issue.
That's the reason why I ask you that.
Is it an INVITE from an ISP ?
06-12-2018 07:09 AM
06-12-2018 07:27 AM
I try to attach the log file but get the error:
The contents of the attachment doesn't match its file type.
Just a simple txt file
Any idea?
JH
06-12-2018 07:38 AM
06-12-2018 07:59 AM
06-12-2018 08:44 AM
Could be an IOS
I shall upgrade to some higher version
It is a 2811, so only the first IOS 15 is supported if I am correct
JH
06-12-2018 08:48 AM
