04-07-2017 08:56 AM - edited 03-17-2019 10:02 AM
I have a Cisco 2921 with CUBE enabled on it with 10 sessions, i'd like to upgrade the number of sessions by adding L-FL-CUBEE-25=, but when i looked on the internet i didn't find any way to upgrade the number of sessions using the purchased lic file. Any help will be appreciated.
Thank you in advance.
04-07-2017 01:23 PM
You will need to get paper based license for 25 sessions from cisco because CUBE uses honor based licenses. So you will not find any separate license file , rather it runs on paper based licenses once you install UCK9.
04-07-2017 02:04 PM
Hello Deepak,
Thank you for your response, so you are saying, that i don't have to install any additional license,right ?. which means if my ISR supports up to 400 sessions, all these sessions are activated in advance but i should buy honor based licences for those 400 sessions ?. Please correcte me if i'm wrong, and sorry for bad English.
Thank you.
04-07-2017 02:07 PM
Yes, no license file to install but you do need a paper based licenses from cisco to increase the number of sessions.So you need to raise a PO for paper based licenses for your CUBE .thanks
04-07-2017 02:15 PM
Thank you so much for you response.
