11-07-2016 11:45 PM - edited 03-17-2019 08:37 AM
I purchase FL-CUBEE-25 , now how can i put this license in router there is no PAK key.
11-08-2016 12:05 AM
CUBE licenses are just paper licenses and aren't (yet) enforced by the router.
GTG
11-08-2016 12:27 AM
CUBE license is righto use License. Which means the features are already available in IOS, you just need to accept the License Agreement to activate it.
Please refer below extract form guide
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-cube-licensing.html
Is CUBE Licensing enforced?
No, CUBE is a paper-based honor license (no file to install) that allows you to run the CUBE RTU (Right-to-Use) feature set after you have the UCK9 license installed.
Please rate and Mark COrrect as applicable<<<<<<<<<<<<<
