CUBE Local Transcoding Interface (LTI) works one way
Evgeny Andreev
Hello!
DTMF ISSUE - Service provider supports only in-band dtmf in voice channel, so i need to transcode it to rfc2833 on CUBE
SP - g711alaw SIP in-band dtmf - CUBE - g711alaw SIP rfc2833 dtmf - INTERNAL NETWORK
Config of CUBE:
voice-card 0                                                         LTI Transcoding
dspfarm
dsp services dspfarm
dspfarm profile 1 transcode
codec g711ulaw
codec g711alaw
maximum sessions 32
associate application CUBE
dial-peer voice 13 voip
destination-pattern .                                            TO INTERNAL NETWORK
session protocol sipv2
session target ipv4:172.28.241.252
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 22 voip
translation-profile outgoing 22
destination-pattern 7241.                                   TO SP
session target dns:xx.yy
voice-class sip localhost dns:xx.yy
codec g711alaw
clid network-number 79265254494
no vad
dial-peer voice 31 voip
description idc 9265254494
translation-profile incoming 30                        INCOMING PEER FOR CALLS FROM SP TO INTERNAL NETWORK (FOR NUMBER TRANSLATION)
incoming called-number 79265254494
codec g711alaw
i configure local transcodin interface (LTI) and it works fine when calls come from SP to internal network, i can see that LTI works with incoming call and DTMF works
#sh dspfarm all
0 1 37.3.6 UP 1 USED xcode 1 127 1468 1510
0 1 37.3.6 UP 1 USED xcode 1 126 1471 1468
0 1 37.3.6 UP N/A FREE xcode 1 - - -
But when i perform outgoing call to SP there is no transcoding, LTI doesn`t catch it
Need help
0 Replies 0
