01-16-2018 07:25 AM - edited 03-17-2019 11:57 AM
I'm using CUBE to perform media forking for call recording. Our call recorder can only handle G.711 but calls can come in with other codecs (e.g G.722 or G.729)
I've tried configuring a transcoder on CUBE, but I still get the error:
%VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1.....
Does CUBE actually support transcoding for forked call legs?
Gordon.
01-16-2018 08:43 AM
Are you using CUCM based transcoding or locally registered? Have you tried CUBE LTI?
Brandon
01-17-2018 12:23 AM
Yes. This is an exert from my config:
voice class codec 2
!Inbound codecs
codec preference 1 g722-64
codec preference 2 g729r8
codec preference 3 g711alaw
video codec h264
voice class codec 3
!Recorder codec
codec preference 1 g711alaw
video codec h264
dspfarm profile 2 transcode universal
codec g729abr8
codec g729ar8
codec g711alaw
codec g729r8
codec g722-64
maximum sessions 4
associate application CUBE
01-17-2018 05:46 AM
Does the profile show active with "show dspfarm profile 2". Can you see the transcoder working with "show dspfarm dsp active" while a call is being attempted?
Brandon
01-17-2018 05:57 AM
Yes
Dspfarm Profile Configuration Profile ID = 2, Service =Universal TRANSCODING, Resource ID = 2 Profile Description : Profile Service Mode : Non Secure Profile Admin State : UP Profile Operation State : ACTIVE Application : CUBE Status : ASSOCIATED Resource Provider : FLEX_DSPRM Status : UP Total Number of Resources Configured : 4 Total Number of Resources Available : 4
No.
What debugs can I use to try and see what's going on here?
Gordon.
01-17-2018 06:04 AM
Have you checked the dial peers that are being selected with "debug voip dialpeer"?
01-17-2018 06:19 AM
Definitely see it being matched:
002927: Jan 17 14:12:41: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore: Calling Number=, Called Number=1198, Peer Info Type=DIALPEER_INFO_SPEECH 002928: Jan 17 14:12:41: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore: Match Rule=DP_MATCH_DEST; Called Number=1198 002929: Jan 17 14:12:41: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore: Result=Success(0) after DP_MATCH_DEST 002930: Jan 17 14:12:41: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin: dialstring=1198, saf_enabled=0, saf_dndb_lookup=1, dp_result=0 002931: Jan 17 14:12:41: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg: Result=SUCCESS(0) List of Matched Outgoing Dial-peer(s): 1: Dial-peer Tag=4000 002932: Jan 17 14:12:41: %VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1 on callID 41090 GUID=505E1AABFAC711E7A448E8B1242118F3
1198 is the DN assigned in the call recorder and dial-peer 4000 is the one pointing at the call recorder:
dial-peer voice 4000 voip description Test Recording System destination-pattern 1198 ...
01-17-2018 06:22 AM
debug ccsip messages
will provide some clues on the CODEC negotiation.
01-17-2018 06:34 AM
Do you have the codec configured on this dial peer? Default if not configured is g.729. Also, what inbound dial peer is being matched?
01-17-2018 06:48 AM
Outbound to recorder:
voice class codec 3 codec preference 1 g711alaw video codec h264 .... dial-peer voice 4000 voip destination-pattern 1198 session protocol sipv2 session target ipv4:... voice-class codec 3
Inbound
voice class codec 2 codec preference 1 g722-64 codec preference 2 g729r8 codec preference 3 g711alaw video codec h264 .... dial-peer voice 410 voip description FROM Jabber Guest VCS session protocol sipv2 session target sip-server incoming uri via 2 voice-class codec 2 offer-all ...
01-17-2018 06:04 AM - edited 01-17-2018 06:05 AM
i see your using G711alaw. are you sure your recorder supports alaw and not ulaw?
add ulaw to the transcoder profile. if that is the issue, it should resolve it.
01-17-2018 06:07 AM
We're in the UK and the recorder is made by a UK company. We both agree that we're using G.711 a-Law here.
Gordon.
01-17-2018 06:09 AM
can you post some CCSIP logs?
01-17-2018 06:44 AM
01-17-2018 06:53 AM
your VCS is not offering alaw, only ulaw.
a=rtpmap:0 PCMU/8000
