01-16-2018 07:25 AM - edited 03-17-2019 11:57 AM
I'm using CUBE to perform media forking for call recording. Our call recorder can only handle G.711 but calls can come in with other codecs (e.g G.722 or G.729)
I've tried configuring a transcoder on CUBE, but I still get the error:
%VOICE_IEC-3-GW: SIP: Internal Error (200, codec mismatch): IEC=1.1.278.7.106.1.....
Does CUBE actually support transcoding for forked call legs?
Gordon.
01-17-2018 06:57 AM
01-17-2018 06:58 AM - edited 01-17-2018 07:00 AM
if it is in the transcode profile, which above, it is not. you need to add ulaw.
dspfarm profile 2 transcode universal
codec g729abr8
codec g729ar8
codec g711alaw
codec g729r8
codec g722-64
maximum sessions 4
associate application CUBE
01-17-2018 07:07 AM
I added u-Law and no change :-(
dspfarm profile 2 transcode universal codec g729abr8 codec g729ar8 codec g711alaw codec g729r8 codec g722-64 codec g711ulaw maximum sessions 4 associate application CUBE
01-17-2018 07:15 AM
seems like you are missing some things in the debugs. I am only seeing the bye to the recorder, I don't see the initial invite.
can you post or PM me the full CUBE config?
01-17-2018 07:44 AM
01-17-2018 07:57 AM
01-18-2018 12:49 AM
@Steven Landon wrote:
You're doing a couple things on this list in your config
Restrictions for Network-Based Recording
* Network-based recording is not supported for the following calls:
* Calls that do not use Session Initiation Protocol (SIP). Must be a SIP-to-SIP call flow
Not doing that.
Flow-around calls
Not doing that
Session Description Protocol (SDP) pass-through calls
Not doing that.
Real-time Transport Protocol (RTP) loopback calls
Not doing that (as it was removed from IOS a while ago)
High-density transcoder calls
Don't think I'm doing that
IPv6-to-IPv6 calls
Not doing that
IPv6-to-IPv4 calls with IPv4 endpoint.
Not doing that
Secure Real-time Transport Protocol (SRTP) passthrough calls
Not doing that
SRTP-RTP calls with forking for SRTP leg (forking is supported for the RTP leg)
Not doing that
Resource Reservation Protocol (RSVP)
Not doing that
Multicast music on hold (MOH)
Not doing that.
