CUBE - NOTIFY for MWI not being passed to B2BUA from Cisco Unity Connection.
Rory Norris
I'm currently integrating CUBE between a SIP B2BUA and CUCM 10.5. All tests have gone extremely well except for the MWI ON/OFF. What I am seeing is that I do not get MWI on a SIP Endpoint when I have a new message, I am using Cisco Unity Connection as my Voicemail server which is registered to my CUCM. I have included a diagram below.
Analysing this issue I can see that the Endpoint does not receive a NOTIFY, working backwards I can see that the SIP Server doesn't receive one from CUBE either. Upon running debug ccsip messages I can see the NOTIFY on the incoming dial peer however nothing is sent to the SIP Server. I also include outputs from the debug and a copy of my config.
Any help would be gratefully received.
Rory.
Hi Rory,
Great, I'm surprised It didn't work when it was configured globally. but it's good that it works when on dial-peer.
If the answer was useful please rate it, so that it will be easier to find when doing a search
Leszek
Leszek Wojnarski
Have you tried enabling:
sip
pass-thru subscribe-notify-events all
Leszek
Leszek thank you for responding on my query.
Enabled ''pass-thru subscribe-notify-events all' on CUBE but still no success.
Have attached latest debug logs. If you still online please take a look whenever you free.
-Rory
Leszek, Good News!!!!
MWI is started working now. I have added the following command in dial-peer and its working now.
"voice-class sip pass-thru subscribe-notify-events all"
Thanks again for your help!!
-Rory
Hi Rory,
Leszek
