ANNOUNCEMENT - The community will be down for maintenace this Thursday August 13 from 12:00 AM PT to 02:00 AM PT. As a precaution save your work.
Highlighted
CUBE on CSR 1000v
I am wondering if anyone has been able to activate CUBE services on a CSR 1000V router? I have it installed on a ESXi 5.5 and acitvated a demo 60-day licence for an AX services.
In the Cisco documentations, it says I just need to type in "voice services voip" but the router does not recognise the command.
License Level: ax
License Type: Paid Subscription
Next reload license Level: ax
cisco CSR1000V (VXE) processor (revision VXE) with 2151294K/6147K bytes of memory.
Processor board ID 9099OPNSUC0
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3988460K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
Any ideas?
Everyone's tags (2)
7 REPLIES 7
Highlighted
Enthusiast
This document details what
This document details what technologies are supported on CSR1000v.
http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/csr1000Vswcfg/csroverview.html#pgfId-1075661
Please rate replies and mark question as "answered" if applicable.
Highlighted
Rejohn, That's the article I
Rejohn,
That's the article I was referring to above. It does not work, with the full demo licence activated.
Highlighted
Enthusiast
Table 1-6 Cisco IOS XE
Table 1-6 Cisco IOS XE Technologies Supported on the Cisco CSR 1000V Cloud Services Router does not list CUBE. Therefore, CSR1000v doesn't support CUBE feature set.
Highlighted
It's a lower version it seems
Cisco IOS XE Software, Version 03.14.01.S - Standard Support Release              Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(1)S1, RELEASE SOFTWARE (fc1)         Technical Support: http://www.cisco.com/techsupport                               Copyright (c) 1986-2015 by Cisco Systems, Inc.                                    Compiled Sun 01-Mar-15 03:58 by mcpre
Highlighted
Enthusiast
Can cofirm that from 3.15S
Can cofirm that from 3.15S version CUBE and SBC are supported.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-virtual-cube.html
Highlighted
Enthusiast
What version of IOS XE are
What version of IOS XE are you using? vCUBE is supported starting on version 3.15S.
Highlighted
Contributor
According to the data sheets:
AppX and AX licenses come with a 25-session Cisco Unified Border Element (CUBE) license. This license (FL-CUBEE-5=) adds 5 additional CUBE sessions.
