CUBE on CSR 1000v
I am wondering if anyone has been able to activate CUBE services on a CSR 1000V router? I have it installed on a ESXi 5.5 and acitvated a demo 60-day licence for an AX services.
In the Cisco documentations, it says I just need to type in "voice services voip" but the router does not recognise the command.
License Level: ax
License Type: Paid Subscription
Next reload license Level: ax
cisco CSR1000V (VXE) processor (revision VXE) with 2151294K/6147K bytes of memory.
Processor board ID 9099OPNSUC0
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
3988460K bytes of physical memory.
7774207K bytes of virtual hard disk at bootflash:.
Any ideas?
7 Replies 7
Rejohn Cuares
Level 4
Level 4
This document details what technologies are supported on CSR1000v.
http://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/csr1000Vswcfg/csroverview.html#pgfId-1075661
Please rate replies and mark question as "answered" if applicable.
Rejohn,
That's the article I was referring to above. It does not work, with the full demo licence activated.
Table 1-6 Cisco IOS XE Technologies Supported on the Cisco CSR 1000V Cloud Services Router does not list CUBE. Therefore, CSR1000v doesn't support CUBE feature set.
It's a lower version it seems
Cisco IOS XE Software, Version 03.14.01.S - Standard Support Release              Cisco IOS Software, CSR1000V Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(1)S1, RELEASE SOFTWARE (fc1)         Technical Support: http://www.cisco.com/techsupport                               Copyright (c) 1986-2015 by Cisco Systems, Inc.                                    Compiled Sun 01-Mar-15 03:58 by mcpre
Can cofirm that from 3.15S version CUBE and SBC are supported.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube/configuration/cube-book/voi-virtual-cube.html
What version of IOS XE are you using? vCUBE is supported starting on version 3.15S.
HumanTorch
Level 5
Level 5
According to the data sheets:
AppX and AX licenses come with a 25-session Cisco Unified Border Element (CUBE) license. This license (FL-CUBEE-5=) adds 5 additional CUBE sessions.
