09-21-2016 04:37 AM - edited 03-17-2019 08:08 AM
Hi Experts,
Can anybody help me out with the following question?
If there is a CUBE pair in HA mode configured (one is active, other is standby), how the media resources would work?
Can both of the CUBEs media resources (XCODE, CONF, MTP) to be registered with CUCM, by using the physical IP addresses of each CUBEs? (Virtual IP would only be used for SIP trunk to reach PSTN via SIP provider.)
I'm afraid only the active CUBE's media resources would be registered...
Many thanks in advance for your time and help!
Tibor
09-21-2016 05:28 AM
Hi Tibor,
From media resource perspective you should be able to configure them on both the CUBEs and register to CUCM simultaneously.
Manish
09-21-2016 06:02 AM
Agree with Manish -
Create different names in each CUBE (eg. CUBE_XCODE_1 and CUBE_XCODE_2) and add both to CUCM. You cannot use the same name in each CUBE or they will cycle between registered and unregistered with CUCM.
09-21-2016 06:19 AM
If the CUBE is deployed in HA fashion only one set from the active CUBE will register as both CUBEs are bound to the same redundancy group IP address. Even if you build another interface on the CUBEs and define different media resource registration names only one will register at a time (from the active CUBE). This is working as design.
09-21-2016 08:14 AM
AFAIK, it will work as Chris says, had a discussion with the BU about this and they confirmed that you would only be able to get the resources registered from one CUBE. As that would affect any call that uses those resources in the event of a failure, it's best to have the PVDMs in a dedicated router.
09-28-2016 12:56 AM
Hi Jamie and All,
Can the DSP capacity to be extended by the SM-X-PVDM modules? Unfortunately none of the modules can be selected in DSP calculator so calculation can not be done with this.
Seems there are some limitations for faxing (codecs are not supported).
Is there any difference in the configuration?
Can this be registered with CUCM as a normal media resource?
Many thanks,
Tibor
09-28-2016 03:17 AM
Sorry for the 2nd/repeated comment, it was just not showing up, I thought could not send the fist one...
Hi Jamie,
Many thanks for your reply!
Just a quick question back:
I can see there are additional DSP modules available for ISR 4xxx: SM-X-PVDM, but the only way of listing them with DSP calculator as result of DSP requirements if there is any E1/T1 module also selected.
Does it mean, if I want to extend the DSP capacity just by adding SM-X-PVDM without any E1/T1 module will not be recognised/work?
Many thanks for your time and your kind help!
Tibor
09-21-2016 08:20 AM
+5 Chris
JB
09-21-2016 07:18 AM
Hi tdudas,
refer this URL. May this help.
https://www.youtube.com/watch?v=-DRYAjJYeuU
regards,
Ritesh Desai
