07-31-2015 01:03 AM - edited 03-17-2019 03:49 AM
Dear Sir/Madam,
I have two ISR 4321 CUBE Routers with one SIP Trunk (25 CUBE) from the provider. I have to place FL-CUBEE-25-RED to one Router or do I have to put FL-CUBEE-25 to both Routers?
BR
07-31-2015 02:34 AM
If the two routers are an active/passive pair, you can use the -RED license. If they are both actively running calls, you need the FL-CUBEE-25 on each.
Aaron
07-31-2015 02:39 AM
07-31-2015 08:33 AM
Please remember to rate useful response, and mark 'answered' when appropriate..
Ta
07-31-2015 02:38 AM
If you are going to use active/standby deployment then you need to go for 1x -RED lic. In case you are going for active/active (loadbalance) deployment, you can go for 2x Regular license.
07-31-2015 02:40 AM
thanks
