CUBE Redundant License
bvanselous
Beginner
Beginner
Are the redundant CUBE licenses (FL-CUBE-xxx-RED, FL-CUBEE-xxx-RED) used only on CUBE pairs with HSRP activated?  Or, should these licenses also be used when a carrier providing SIP trunks delivers SIP traffic to geographically separate CUBEs in a primary\failover scenario where the SIP traffic would only be sent to the seconday CUBE in the event of failure to reach the primary CUBE?
1 ACCEPTED SOLUTION
Prashanthi Velpula
Below is brief information on CUBE Redundant configuration and licensing:
++ The " RED " keyword means its for Redundancy feature
++ The Redundancy license applies to box-to-box redundancy in an Active/Standby deployment ( HSRP config )
Geographic redundancy: Use Single-Use CUBE License
++ If you need geographic redundancy, each box is licensed with Single-Use CUBE License
CUBE High-Availabilty using HSRP: Below is the resource link for config example:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5640/products_configuration_example09186a0080b40d82.shtml#req
Hope the above is informative.
Thanks and Regards
Prashanthi Velpula
4 REPLIES 4
Prashanthi Velpula
Thanks and Regards
Prashanthi Velpula
Hi there,
If a customer has orignally deployed CUBEs in an HSRP configuration using the -RED- licence, but then wants to move the CUBEs to separate data centre, is there an upgrade licence available to take them to the full CUBE licence for each gateway?
Many thanks,
Mike.
Hi Michael,
Below is the guide:
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6790/gatecont/ps5640/prod_qas09186a00801da69b.html
Some detail information:
FL-CUBEE-XXX licenses apply to the Cisco 2900 and 3900 series ISR G2 routers
++ The ISR G2 routers have additional features, such as box-to-box redundancy
FL-CUBEE-XXX-RED  license enables the purchased session  count for both platforms, e.g.  the FL-CUBEE-100-RED purchased for two  Cisco 3945 routers enables a  100-session SIP trunk on both the Active  and Standby routers
- Applicable on the router that is Active at one time
++  Now if customer wants to use Active-Active that means, the  FL-CUBEE-XXX-RED is not a valid license and does require to purchase the  normal single-use session license
OR consider the below:
- CUBE #1: FL-CUBEE-100-RED *** This can be used as normal single-use session license and RED is additional on top
-  CUBE #2: NO CUBE LICENCE *** This will require normal single-use licese  and wont have the RED additional feature which is not required anyways  ***
Hope the above is informative and helpful. And please do bear in mind this is feature license and its subjective to feature
++ Once you have normal feature license, you are good to start using that feature and any additional need to be topped up !
Prashanthi Velpula
- See more at: https://supportforums.cisco.com/message/3870393#3870393
Hi Michael,
Below is the guide:
Prashanthi Velpula
