CUBE registration with ISTP
Kyle Sullivan
I am trying to integrate CUBE into my lab environment for testing. I have it enabled CUBE of a Cisco ISR2951 running c2951-universalk9-mz.SPA.157-3.M5.bin. This router is also running CME Version 10.0. I have also setup an account with an ISTP. (Flowroute)
IPBCME01#sh cube status
CUBE-Version : 11.5.2
SW-Version : 15.7.3.M5, Platform CISCO2951/K9
HA-Type : none
Licensed-Capacity : 200
I am running into an issue where all the CME ephone-dn's are trying to register with the SIP ISTP. I'm thinking that due to the constant connection attempts with improper credentials, the ISTP is just rejecting everything.
1. Can CUBE and CME co-reside on the same router?
2. If that is the case, how do you configure the CUBE so only the sip-ua defined registers with the ISTP? I do not need nor expect the ephone-dns to continually try and register.
Kyle
You put CME and CUBE on same router. To disable dn registration with your
ITSP, but the keyword no-reg when you configure your ephone-dn numbers.
e.g
ephone-dn 10
number 1000 no-reg
**** please remember to rate useful posts.
e.g
ephone-dn 10
number 1000 no-reg
Kyle Sullivan
Mohammed,
Thank you for the response. That helped correct my ISTP registration issue.
