CUBE Router and Voice Gateway
dyep110581
Hi All,
I would like to know the difference between a CUBE Router and a Voice Gateway. Thanks in advance.
18 Replies 18
Hello, Everyone.
Could someone please help with a question I have? The output is from a Voice Gateway Router that that has an E1 card. I would like to do an IP to IP dial peer. Can someone please tell me if the Cube license is present?
GW1#sh version
Cisco IOS XE Software, Version 17.06.03a
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.6.3a, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Fri 08-Apr-22 04:52 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2022 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: (c)
GW1 uptime is 2 weeks, 2 days, 21 hours, 14 minutes
Uptime for this control processor is 2 weeks, 2 days, 21 hours, 16 minutes
System returned to ROM by PowerOn
System image file is "bootflash:isr4300-universalk9.17.06.03a.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None Smart License None
securityk9
appxk9
AdvUCSuiteK9 None Smart License None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None Smart License None
uck9 uck9 Smart License uck9
securityk9 None Smart License None
ipbase ipbasek9 Smart License ipbasek9
The current throughput level is 100000 kbps
You do not see if the gateway is using any Cube licenses by that command and also all licenses are consumed by Smart Licensing. So if you have licenses available in your Smart Licensing portal it can be consumed by the gateway. To see what it uses you use the show license summary command.
Response Signature
Thank you, Roger.
I will check using the command you suggested.
rimishr2
Voice Gateway - IP to TDM connection. Example, it can be CUCM>>>>>SIP/MGCP/H323>>>>Voice Gateway>>>PRI/FXO/T1 CAS/E1 R2.
CUBE - IP to IP Connection. It can be SIP to SIP or H.322 to SIP(this is not recommended though).
