10-19-2016 11:24 PM - edited 03-17-2019 08:25 AM
Hi All,
Calling Number : 27214921100
Called Number : 0827718822
CUCM---------------------CUBE (2900 |15.4 M3)------------------ITSP
182.17.3.5 182.30.50.13
when making oubound calls, cube is sending 503 service unavailable. we have working site as well with same model cube and configuration, its working there.
Cucm send invite and it gets 100 trying after that 503 service available is coming from CUbe imeediately. even not reaching to external leg.
Oct 17 12:14:33.836: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:0827718822@182.17.3.5:5060 SIP/2.0
Via: SIP/2.0/TCP 182.30.50.13:5060;branch=z9hG4bK51212b3efc1
From: <sip:8834@182.30.50.13>;tag=572717~9ef3738a-e9a5-419e-997d-cad9d7f84eb1-30598611
To: <sip:0827718822@182.17.3.5>
Date: Mon, 17 Oct 2016 10:15:14 GMT
Call-ID: 96cbea80-8041a4b2-28fb-d321eac@182.30.50.13
Supported: timer,resource-priority,replaces
Min-SE: 1800
User-Agent: Cisco-CUCM10.5
Allow: INVITE, OPTIONS, INFO, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY
CSeq: 101 INVITE
Expires: 180
Allow-Events: presence, kpml
Supported: X-cisco-srtp-fallback,X-cisco-original-called
Call-Info: <sip:182.30.50.13:5060>;method="NOTIFY;Event=telephone-event;Duration=500"
Call-Info: <urn:x-cisco-remotecc:callinfo>;x-cisco-video-traffic-class=DESKTOP
Cisco-Guid: 2529946240-0000065536-0000000952-0221388460
Session-Expires: 1800
P-Asserted-Identity: <sip:8834@182.30.50.13>
Remote-Party-ID: <sip:8834@182.30.50.13>;party=calling;screen=yes;privacy=off
Contact: <sip:8834@182.30.50.13:5060;transport=tcp>
Max-Forwards: 69
Content-Length: 0
Oct 17 12:14:33.836: //-1/96CBEA800000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Oct 17 12:14:33.840: //16773/96CBEA800000/SIP/Media/sipSPISetMediaSrcAddr: Media src addr for stream 1 = 182.17.3.5
Oct 17 12:14:33.840: //-1/xxxxxxxxxxxx/SIP/Media/sipSPIReserveRtpPort: reserved port 16820 for stream 1
Oct 17 12:14:33.840: //16773/96CBEA800000/SIP/Media/sipSPIAddSDPMediaPayload: Preferred method of dtmf relay is: 6, with payload: 101
Oct 17 12:14:33.840: //16773/96CBEA800000/SIP/Media/sipSPIDisplayStreamInfo:
Stream type : voice+dtmf
Media line : 1
State : STREAM_IDLE (1)
Stream address type : 1
Callid : -1
Peer Callid : -1
RTP/SRTP Negotiated : 0
Negotiated Codec : No Codec , bytes :0
Nego. Codec payload : 255 (tx), 255 (rx)
Negotiated DTMF relay : inband-voice
Negotiated NTE payload : 0 (tx), 0 (rx)
Negotiated CN payload : 0
Media Srce Addr/Port : [172.17.3.5]:16820
Media Dest Addr/Port : [ - ]:0
Oct 17 12:14:33.840: //16773/96CBEA800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 100 Trying
Date: Mon, 17 Oct 2016 12:14:33 GMT
CSeq: 101 INVITE
Allow-Events: telephone-event
Server: Cisco-SIPGateway/IOS-15.4.3.M3
Content-Length: 0
Oct 17 12:14:33.844: //16774/96CBEA800000/SIP/Media/sipSPICopyStunConfigFromPeerToCCB: Firewall traversal is not enabled
Oct 17 12:14:33.844: //16774/96CBEA800000/SIP/Call/sipSPICallInfo:
The Call Setup Information is:
Call Control Block (CCB) : 0x0x229FC460
State of The Call : STATE_DEAD
TCP Sockets Used : YES
Source IP Address (Sig ): 0.0.0.0
Destn SIP Req Addr:Port : :0
Destn SIP Resp Addr:Port : :0
Destination Name :
Disconnect Cause (CC) : 188
Disconnect Cause (SIP) : 200
Oct 17 12:14:33.844: //16773/96CBEA800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 503 Service Unavailable
To: <sip:0827718822@182.17.3.5>;tag=A0DFD58-784
CSeq: 101 INVITE
Reason: Q.850;cause=0
Content-Length: 0
Oct 17 12:14:33.868: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:0827718822@182.17.3.5:5060 SIP/2.0
Max-Forwards: 70
CSeq: 101 ACK
Content-Length: 0
Oct 17 12:14:33.868: //16773/96CBEA800000/SIP/Call/sipSPICallInfo:
Call Control Block (CCB) : 0x0x229F5DB0
Calling Number : 8834
Source IP Address (Sig ): 182.17.3.5
Destn SIP Req Addr:Port : 182.30.50.13:5060
Destn SIP Resp Addr:Port : 182.30.50.13:33439
Destination Name : 182.30.50.13
Oct 17 12:14:33.868: //16773/96CBEA800000/SIP/Call/sipSPIMediaCallInfo:
Number of Media Streams: 1
Media Stream : 1
Negotiated Codec Bytes : 0
Negotiated Dtmf-relay : 0
Dtmf-relay Payload : 0 (tx), 0 (rx)
Source IP Address (Media): 182.17.3.5
Source IP Port (Media): 16820
Destn IP Address (Media): -
Destn IP Port (Media): 0
Orig Destn IP Address:Port (Media): [ - ]:0
Disconnect Cause (CC) : 63
Disconnect Cause (SIP) : 503
Thanks in advance
Solved! Go to Solution.
10-20-2016 07:35 PM
Both are delayed offer.
