07-07-2020 02:21 PM
Hello ,
CUCM => (SIP) => CUBE => ISDN(E1) (PSTN)
Inbound calls suddenly stopped work. Router receives the call on POTS dial-peer , sends to CUCM via SIP. Once the router receives Trying and Ringing from CUCM , it immediately sends Cancel to CUCM with Reason: Q.850;cause=47.
Attaching debugs.
Would appreciate your help,
Thanks in advance
Ilyas
07-07-2020 09:20 PM
please share the calling number, called number and timestamp to look into debugs.
07-08-2020 02:50 AM
Hi Ritesh,
Thanks for reply.
Calling number : 502892796
Called : 5655620
There is only one inbound call in all debug files.
07-08-2020 04:38 AM - edited 07-08-2020 04:39 AM
@ilyas.safarov have looked at the logs you uploaded.
between CUCM and Voice Router you have SIP trunk.
Before the CANCEL event, below is the error being reported.
Sending CANCEL to the transport layer
Jul 7 08:46:54.675: //1648807/3E46959A8127/SIP/Transport/sipSPITransportSendMessage: msg=0x66B8C2C0, addr=192.168.3.10, port=5060, sentBy_port=0, local_addr=, is_req=1, transport=1, switch=0, callBack=0x347EA070
Make sure your SIP trunk between Voice Router and CUCM is UP. I suspect voice router is unable to communicate with CUCM 192.168.3.10, port=5060.
SIP CANCEL event
Jul 7 08:46:54.675: //1648807/3E46959A8127/SIP/Info/ccsip_call_statistics: Stats are not supported for IPIP call.
CANCEL sip:5655620@192.168.3.10:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.3.1:5060;branch=z9hG4bK22523A4
To: <sip:5655620@192.168.3.10>
Date: Tue, 07 Jul 2020 08:46:54 GMT
Call-ID: 3E49A2FB-BF6511EA-87EEEB8A-D84D5E44@192.168.3.1
CSeq: 101 CANCEL
Max-Forwards: 70
Timestamp: 1594111614
Content-Length: 0
can you attach below details here please.
- show running config
- show dial-peer voice inout
- show inventory
Suggestion, next time when you enable the traces and share it, share it in single file rather in multiple files.
08-12-2020 07:55 AM
