CUBE SIP Lineside Phone Proxy
Hi All,
I'm trying to do a lab for the linside feature in CUBE for external SIP phones to register with the call manager without VPN.
i should mention it is my first time to configure CUBE and also it is my first time to configure CUCM 10.0
hosts IP addresses:
CUBE IP address:172.16.10.100
CUCM: 172.16.10.110
i followed the procedure in the below link, and the external SIP phones registered fine.
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_interop/configuration/15-mt/cube-interop-15-mt-book/voi-cucm-lineside.html#reference_956BE6CA0F3A43EB9D7E538ABE666177
but i can't make calls between two external phones, or between an external and internal phone.
i collected the output of "debug voice phone-proxy all" for two external phones. i also collected the output of "debug voice dialpeer" for a call between the two phones (the two phones are considered as external phones).
all the logs are attached
can anyone help me here please?
Maheshwar Tayal
Level 4
Level 4
Hello
Is this issue resolved for you , I was looking for similar solution
Hi Mate,
You can use the below link.
https://ciscocollab.wordpress.com/2014/04/08/cube-sip-lineside-phone-vpn-configuration/
