2292
Highlighted
Participant
CUBE T.38 Re-invite with two m-lines
Hi guys
Somebody found a workaround to CUBE works fine when the the ITSP send sip reinvite t.38 with two m-lines for outbound fax?
Fax server <<< SIP/UDP>>> CUCM <<< SIP/UDP>>> CUBE <<< SIP/UDP>>>SBC/ITSP or
Fax server <<< SIP/UDP>>> CUBE <<< SIP/UDP>>>SBC/ITSP
15 REPLIES 15
Highlighted
Ayodeji,
Do you know if CUBE  IOS in theory on papar  support the RFC 3264? When it does not support mulitple m-lines, I think it does not. So if a ITSP actually follow whats in RFC3264 then we have an issue with CUBES and T38.
I don't care if its one or two m-lines as long as it works. And it works if the RFC's are followed.
BR
Ornulf
