05-28-2021 08:25 AM
I've getting the following error on an inbound call on my CUBE:
%SIP-2-TLS_HANDSHAKE_FAILED: TLS handshake failure
Any suggestions as to how to troubleshoot this? I thought I'd followed the instructions for setting up SIPS.
I'm on IOS-XE 17.03.03
Gordon.
05-28-2021 08:45 AM
It could help us help you if you where to actually describe what you have done to setup SIPS? Sharing the running configuration is also a great thing to do as that would give us the possibility to verify your setup and removes the guess work out out the cycle.
05-28-2021 08:48 AM
Have a look at this presentation from Cisco Live 2018 in Orlando. https://www.ciscolive.com/c/dam/r/ciscolive/us/docs/2018/pdf/BRKCOL-3224.pdf
It contains some valuable information on the topic at hand.
05-28-2021 01:20 PM
That is a dense and useful document. The only problem I've got is that the "openssl s_client" command isn't working. I'm wondering if it's due to some of the CUBE security enhancements.
I tried adding my IP address to "ip address trusted list" section but I still can't connect.
Gordon.
