Community Helping Community
1397
Contributor
CUBE: Using SIP-profiles to repair ip-addresses behind a NAT firewall
Does anyone have shareable examples?
I have a CUBE behind a VMwareEdge firewall, performing NAT towards the ITSP.
When I receive an "OPTIONS" from the ITSP, the external ip-address is presented to my CUBE, and teh request is rejcted as shown below.
*Jan  5 10:32:49.634: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
OPTIONS sip:2.106.44.22 SIP/2.0
Via: SIP/2.0/UDP 213.83.164.141:5060;branch=z9hG4bK74df1bb9;rport
Max-Forwards: 70
From: "hemmeligt" <sip:hemmeligt@213.83.164.141>;tag=as75ab17ef
To: <sip:2.106.44.22>
Contact: <sip:hemmeligt@213.83.164.141:5060>
Call-ID: 11d4450f7621780f149be57b37f24c5e@213.83.164.141:5060
CSeq: 102 OPTIONS
User-Agent: Condor_gw1
Date: Thu, 05 Jan 2017 10:48:24 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO, PUBLISH, MESSAGE
Supported: replaces
Content-Length: 0
Sent:
SIP/2.0 400 Bad Request - 'Invalid IP Address'
To: <sip:2.106.44.22>;tag=46A52250-1E1F
Date: Thu, 05 Jan 2017 10:32:49 GMT
Server: Cisco-SIPGateway/IOS-15.4.3.M
CSeq: 102 OPTIONS
Content-Length: 0
My CUBE are using 10.190.87.100 for the interface receiving packets from the ITSP.
CUBE configuration attached, "voice class sip-profiles " most certainly flawed.
fortvald
Everyone's tags (3)
1 ACCEPTED SOLUTION
Highlighted
Participant
Please correct me if I am wrong.
Do you wish to modify OPTIONS sip:2.106.44.22 SIP/2.0 to OPTIONS sip:10.190.87.100 SIP/2.0 ?
if that's the case then you would need add the following line in your sip-profiles.
request OPTIONS sip-header SIP-Req-URI modify "sip:2.106.44.22 SIP/2.0" "sip:10.190.87.100 SIP/2.0"
Please rate and mark if helpful
Adarsh Chauhan
Please rate and mark correct if helpful
Adarsh Chauhan
3 REPLIES 3
Highlighted
Participant
Adarsh Chauhan
Adarsh Chauhan
Contributor
Just tried the suggested
Just tried the suggested configuration, no change in behavoir though.
result from "Tools Catalog SIP-Profile Test Tool" attached.
Also current config. Any help appreciated
fortvald
Contributor
The advise was right on the
The advise was right on the spot.
Unfortunately I was also missing the "inbound", for sip profiles, once that was corrected the profiles did their job.
fortvald
Content for Community-Ad
FusionCharts will render here
