09-01-2015 10:34 PM - edited 03-17-2019 04:11 AM
Hello All,
I referred the document for SIP integration between CUC and CUCM. According to the document I done each and every changes mentioned in the document. But still it is CUC is not communicating with CUCM.
Pls help.
Kiran Chavan
+91 9870876096.
09-01-2015 10:55 PM
What is the issue you are facing?
First check whether call is hitting CUC or not from CUCM. This will tell us whether issue is at CUCM or CUC side.
