CUC 8.6.2 coulnd't installation
ozden ozdugun
Beginner
Beginner
I want to install Cisco Unity connection 8,6,2 n the vmware.I put  the cd on the server cd room.and craete vm machine but ı only see install cisco unified manager .I couldn't see choose unity.
8 Replies 8
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
That implies that the OVA template you used for CUC server is incorrect and thus not recognized as option to install CUC. Make sure you first deploy CUC OVA template before starting the installation.
Hi chris ;
ı use the ova cuc 11.5 on cisco page;have you know where the cuc 8.6.2 ova ,can we download
I download this page ;ova is CUC_8.6.2_vmv7_v1.5.ova;but  there is no change.we send you a jpeg
Jaime Valencia
Hall of Fame Cisco Employee Hall of Fame Cisco Employee
What are the VM specs you're using?
java
if this helps, please rate
esxi ersion 5.5 ı sent you a jpeg
Jaime Valencia
Those specs do not match, adjust as per this page:
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/virtualization-cisco-unity-connection.html
java
Hi Jamie.
I configure esxi 5.1 and CUC_8.6.2_vmv7_v1.5.ova on the exi then power with 8.6.2 cisco unity cd but there is no change.only ı could configure cucm ı couldn't configure cuc
Recognize Your Peers
