02-22-2018 01:44 PM - edited 03-17-2019 12:16 PM
CUCM 11.5 CUC 11.5 IMP 11.5
So I have extension 7501 with voicemail. I have 7502 & 7503 as alternate extensions. Also, if 7502 & 7503 have callers ring busy or RNA, callers go to *7501. And 7502 & 7503 access 7501 voicemail fine.
Main question is: when 7501 gets a voicemail, can the voicemail Light notification be activated on 7502 & 7503 also ? I don't see anywhere to enable that. Thanks !
Solved! Go to Solution.
02-22-2018 02:36 PM
Go to 7501, Edit -> MWI, and add them there.
02-22-2018 02:36 PM
02-22-2018 02:57 PM
