Walkthrough Wednesdays
325
Kent Drugge
Beginner
CUC Alternate Extension notification
CUCM 11.5 CUC 11.5 IMP 11.5
So I have extension 7501 with voicemail. I have 7502 & 7503 as alternate extensions. Also, if 7502 & 7503 have callers ring busy or RNA, callers go to *7501. And 7502 & 7503 access 7501 voicemail fine.
Main question is: when 7501 gets a voicemail, can the voicemail Light notification be activated on 7502 & 7503 also ? I don't see anywhere to enable that.  Thanks !
1 ACCEPTED SOLUTION
Jaime Valencia
Hall of Fame Cisco Employee
Go to 7501, Edit -> MWI, and add them there.
java
if this helps, please rate
2 REPLIES 2
Jaime Valencia
java
Excellent, too easy peasy. Thank you !
Content for Community-Ad
Spotlight Awards 2021
