09-11-2020 10:35 PM
We have a setup of cucm and cuc 12.5. we have auto attendant for PSTN calls. dial # or cucm local number. Problem is auto attendant cant transfer the call. It always say "you cannot be transferred to this number etc..." I already checked " Allow Transfers to Numbers Not Associated with Users or Call Handlers"
09-11-2020 11:07 PM
Check if the Voicemail ports has proper CSS to reach the extensions.
09-11-2020 11:31 PM
Update: what happens now is that the call loop to auto attendant greeting if we enter the local number directly. though it works fine when using caller input.
09-12-2020 06:11 PM
I dint understand that. so u mean when trying to dial any extensions from AA, you get the call handler greeting ?
