05-04-2012 01:27 PM - edited 03-16-2019 10:59 AM
I installed the CUC Locale Portuguese BR but i not able to change the default system language on System Settings -> System Default Language.
I not upload the license yet this could be the reason?
05-04-2012 02:18 PM
What version of CUC are run running and do you see the new install language available in the drop down?
-Luis
05-04-2012 06:33 PM
No, you do not need license in order to do this. Did it install correctly, do you see it as available language when you go for example to define user template?
What exact version of CUC are you running and what version Locate did you install?
Chris
05-04-2012 07:06 PM
Ok, yes i install in OS Admin, after that i reboot the server and the locale did not appear.
CUC Version 8.6.2
I download the last version of the locale for CU:
uc-locale-pt_BR-8.6.2.1-25.cop.sgn
05-04-2012 07:30 PM
Looks like you are hitting this bug:
Make sure you CUC is on the latest SU, which is 8.6(2a)SU1.
-Luis a.
05-05-2012 09:53 AM
Hi Leonardo,
I really think that Luis may be onto something here + 5 "L"
There are different 8.6.2 locales depending on the exact version
of Unity Connection you are running;
Revised April 25, 2012
Note•All locales other than ENU are released for Connection 8.6(2) Engineering Special 12. Connection 8.6(2) ES 12 locales are supported only with Connection 8.6(2) ES 12.
•All locales other than ENU are released for Connection 8.6(2) SU 1 (ES 25). For more information on the supported engineering-special versions with these locales, please contact Cisco Technical Assistance Center (TAC).
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/8x/release/notes/862cucrn.html#wp1300703
You may want to try this version instead;
Cisco Unity Connection Locale Installer 8.6(2) ES12 - Brazilian Portuguese
uc-locale-pt_BR-8.6.2.1-12.cop.sgn
Cheers!
Rob
"Everything is broken" - Bob Dylan
05-05-2012 10:16 AM
05-05-2012 12:49 PM
I made an upgrade from CUC 8.0 to CUC 8.6.2 and after i installed the locale, is not listed!
I will try to remove and install again if not work i will open a case on Cisco TAC.
Thanks!
