04-20-2016 10:26 PM - edited 03-18-2019 11:56 AM
Hi all guys.
I have a CUCME 8.6 and CUCE 8.6. I'm using an Auto Attendant with basic script (Thanks for calling XX, if your know the extensión number please enter it now).
I have phones with 3 (1XX) and 4 (7XXX) extensión length. Can I configure the script to accept to enter an extensión of 3 or 4 digits?
I have permited only 3 digits in the extensión length, if I chage to 4 digits, then I cannot call phones with 3 digits.
Thanks a lot for your help.
Best regards.
David
04-20-2016 10:52 PM
Hi David,
If you have set the extension length to 4, then while dialing 3 digit extensions you can press # after dialing the digits so that the system wont wait for the next digit.
Rajan
04-21-2016 06:21 AM
Hi Rajan, thanks a lot for your answer.
Just a question, is it posible to configure something like: Extensión Length: <=4 ?
Thats because user culture, they want to enter 3 o 4 digits and the system do the trasfer.
Thanks again.
David.
