joel
Beginner
CUCIMOC - LDAP question
My CUCIMOC does desk phone control and works as a softphone but LDAP fails. I don't understand how LDAP needs to be setup.
LDAP integration is done in the CCM, Do I still need LDAP for each MOC?
If LDAP is not working in the client side, how does it get authenticated to connect, is it via the CCM?
I get an LDAP disconnected error.
4 REPLIES 4
msaleh5353
Beginner
II would try different port numbers for ldap (instead of 3268), e.g. 389 or 636 (if secure) and use ldaps://
htluo
Engager
Could you check [HKEY_CURRENT_USER\Software\Policies\Cisco Systems, Inc.\Client Services Framework\AdminData] ?
If there's data there, could you also post a screenshot of that one?
Thanks!
Michael
http://htluo.blogspot.com
Michael,
I dont see any Cisco under Polices. There is just Microsoft.
What do I need in the feed LDAP_AttributeName_userLogonName?
should be "userPrincipalName".
Michael
Content for Community-Ad
Spotlight Awards 2021
