CUCM 10.5.1 - SRST and PSTN calls
Ayaz Khan
call preservation is not on by default with H.323, see this blog post for the requirements:
http://josonone.blogspot.com/2012/06/h323-call-preservation.html
Shadi Shami
Level 7
Level 7
check if there is any Media Resource involved and the RTP (audio)  is terminated there such as MTP/ Transcoder.
Thank you,
Shadi
Thanks Sabastein ! ! ! ! the command you suggested worked ! !
