12-01-2014 12:27 AM - edited 03-17-2019 01:08 AM
Is CUCM 10.5 compatible with UCCX 8.5.1? I couldn't find a document regarding this one.
Thanks.
Solved! Go to Solution.
12-01-2014 01:06 AM
The matrix for 8.5.1 SU4 (the latest) is here : http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_8.5(1)_SU4
CUCM 9.1(2)SU1 is the latest version it is compatible with, so no is the answer to your question.
Aaron
12-01-2014 01:06 AM
It is not supported.You need to have at least CUCM 9.1
http://docwiki.cisco.com/wiki/Unified_CCX_Software_Compatibility_Matrix_for_10.5(1)
Cisco Unified Communications Manager and Business Edition 60001 and 70001 | Gateways for Outbound Agent and IVR2 | Cisco MediaSense | Cisco Unified Presence Server (CUPS) | Cisco SocialMiner3 | Cisco Prime Collaboration | ||
9.x | 10.x | Prime Deployment | Prime Assurance5 | ||||
| Router Series
Cisco IOS
12-01-2014 01:06 AM
Aaron
12-01-2014 01:06 AM
| Router Series
Cisco IOS
