CUCM 10.5 Encrypted control and media
vipersl65
Level 4
Level 4
When a CUCM is encrypted;
1) It uses TLS for signaling and can fallback to TCP, correct?
2)for UDP it uses SRTP , correct?
3)any doc showing the encrypted ports uses?
thanks
2 Accepted Solutions
George Thomas
Level 10
Level 10
Correct, TLS fallbacks to TCP in mixed mode.
Voice uses SRTP if the Phone security profile is set for SRTP (Encrypted).
Here is the port list:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/port/10_0_1/CUCM_BK_T537717B_00_tcp-port-usage-guide-100/CUCM_BK_T537717B_00_tcp-port-usage-guide-100_chapter_01.html
Please rate useful posts.
RTP and SRTP uses the same port range.
George Thomas
Level 10
Level 10
thanks George.  Now, for the SRTP ports, can they be the same as the RTP ports?  Reason I asked is we are already allowing the RTP ports and wondering if I have to create another firewall rules just for SRTP
thanks
thanks
