CUCM 10.5 Install and Upgrade Guide
Scott Hanson
Level 3
Level 3
Does anyone have the link to this document that is NOT using Prime Collaboration Deployment?  Can;t seem to find anything but that.
All replies rated.
Thanks in advance!
Deepak Rawat
You can refer to the below upgrade guide for CM 10.0(1). It should be valid for 10.5(1) as well since there does not seem to be a specific one for 10.5(1) :
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_0_1/CUCM_BK_U4214F9D_00_upgrade-guide-cucm-100.html
In addition to above information, you can just hover on the CM version you are planning to upgrade on 10.5 train using the below link and then go through the CUCM Readme that will list all the important documentation for that particular version else as mentioned above 10.0(1) upgrade documentation should be good enough
https://software.cisco.com/download/release.html?mdfid=285963825&flowid=77896&softwareid=282074295&release=10.5(2)SU3a&relind=AVAILABLE&rellifecycle=&reltype=latest
Deepak
Bob Fitzgerald
Level 4
Level 4
Hi Scott,
I know this post is a bit old, but in case you haven't found it yet (or stopped looking for it),  you can find the 10.5 upgrade guide here.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/upgrade/10_5_1/cucm_b_upgrade-and-migration-guide-105.html
I hope that helps.
