04-21-2015 09:45 AM - edited 03-17-2019 02:44 AM
After upgrading to CUCM 10.5 my speeddial phone sevice broke. So after fussing with the free phone service in the cisco sdk, and others from Myvoipsource(a good source) I've finally kludged a simple JSP page to do it. It only edits the 1st 6 entries, but that's easy to change. This is a very simple app that uses AXL and soap, so please forgive my poor programming skills.
Installation:
Install Java sdk(jre 7), then apache tomcat(v 7). Make a directory under webapps, like Speedial, than copy over the sd.txt file and rename it to sd.jsp into it. Should work without further imports. If you are using self-signed certs on CUCM you will have to import them into the java default keystore, instuctions here:
http://www.chrissearle.org/2007/10/25/Adding_self-signed_https_certificates_to_java_keystore/
This is based on the kstearns source but modified to be completely self contianed, so you don't need the cisco sdk, or any jar files or classes, etc.
Now just make a phone service with the following url:
http://yourserver:8080/speeddial/sd.jsp?name=#DEVICENAME#
Hope this helps
05-01-2015 08:04 AM
