CUCM 10.5 - PLM - Certificate Error
wilsonsant
Frequent Contributor
Hi Guys,
The PLM page is presenting error certificate. I verified the NTP and is syncrhonized.  I believe that the problem is related with date. When I try
change the date is requested for me delete all NTP, but, when I try to delete the CUM don´t let.
admin:set date 15:32?
Syntax:
set date HH:mm:ss:MM/DD/YY
HH:mm:ss : The time format (24 hours format)
MM/DD/YY : The date format.
Note: Following format is also accepted:
MM/DD/YYYY : The date format.
admin:set date 15:32:00/02/07/2017
This server, is configured to synchronize with external NTP
server(s). Date/time cannot be changed on this server.
Please delete all of the configured external NTP servers.
Command is unsuccessful.
admin:
admin:
admin:utils ntp server delete
1: 10.12.1.1
a: all
q: quit
Choice: 1
Restart NTP (y/n): y
10.12.1.1 will be deleted from the list of configured NTP servers.
Continue (y/n)?y
10.12.1.1 : [The NTP server was not deleted. At least one NTP server is required.]
I used the information about two links without sucess:
https://supportforums.cisco.com/discussion/12104251/security-error
http://www.cisco.com/c/en/us/support/docs/cloud-systems-management/prime-license-manager/200224-Troubleshoot-Common-Issues-in-ELM-PLM.html
Any have idea, about this?
Wilson
Chris Deren
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
What is the error you are getting?
Post a screen shot and the exact URL you are accessing.
Do you have self signed Tomcat cert or is the cert signed by trusted CA?
Chris Deren
Hall of Fame Master
wilsonsant
Hi Chris,
Thanks a lot for Your contact. After to do post, I change the date in Gateway (the gateway was
wrong time) and the solve problem. The CUCM that I am doing test is related my laboratory.
The message was "Error certificate"
Wilson
Recognize Your Peers
