11-01-2018 11:26 AM - edited 03-18-2019 12:33 PM
We are working with a Client in setting up RDP. After we created RDP when calling the physical extension the call is not be routed to the cell phone(remote number). Can anyone assist with this?
11-01-2018 11:33 AM
One of the most common issues is the Line Association is not checked in the Remote Destination configuration, check that and let me know.
11-01-2018 11:54 AM
11-01-2018 12:28 PM
Take a screenshot of your Remote Destination as well as your Remote Destination Profile please
11-01-2018 12:41 PM
Here is the RDP Config and Profile
11-01-2018 12:47 PM
Everything looks good....that is assuming your CSS/Partions are allowing the call.
Also is "7" your PSTN access code?
11-01-2018 12:57 PM
11-01-2018 01:13 PM
Drop the timer in the Remote Destination from 4 seconds to 1 second and make the call again.
11-01-2018 01:16 PM
11-01-2018 01:49 PM
Let me see the route pattern for the outbound call and the OFFICE_CSS that the profile is using
11-01-2018 01:54 PM
I can't make out the name of the rerouting CSS ---- but does it include a partition that will match the pattern you are trying to dial?
11-01-2018 01:55 PM
I just asked him to get a screen shot of that!
11-01-2018 02:13 PM
11-02-2018 06:06 AM
Here is the screenshots of partition.
We are dialing 7 609-XXX-XXXX
11-02-2018 06:31 AM
When you say the call could not be routed, what is happening? Busy? Error message? Dead air?
I see you are also using time schedules....did you check those to make sure they aren't causing an issue?
Also, you can check RTMT (assuming CUCM v10+) for in the Real Time Voice and Data section and search for the call at that date/time. See if the redirected call is even leaving CUCM.
Also, do all RDPs fail or just this one? There is a check box on your PSTN facing trunk in the outbound calls section about redirecting diversion headers ---- I'm making a ton of assumptions about your env, but that probably should be checked. However, if it is not and you want to test by checking it just know it will reset the trunk and disrupt any call setup in progress.
