Walkthrough Wednesdays
372
it-auri-group
Beginner
CUCM 10.5 sip 404 to hunt pilot
Hi guys,
I have configured Hunt Pilot with 777XXXXXXXXXX number, calls from CUCM extensions work normally.
Calls from trunk directly to extension is ok, but calls to hunt pilot number not work - we have reply sip 404.
Trunk CSS is main_css, all extensions are here. I test any partitions in Hunt Pilot configuration, no changes.
DNA report - Route this pattern. What i should to do now?
Help please.
2 REPLIES 2
Vaijanath Sonvane
VIP Engager
Please post the router configuration and failed call logs.
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
 Here is Call log from CUBE:
Jun 18 10:59:42.493: //2247/AF677048A3C6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP CUBEIP:5060;branch=z9hG4bKD810A1
To: <sip:777XXXXXX7006@CUCMIP>
Date: Tue, 18 Jun 2019 10:27:33 GMT
Call-ID: 2771819-90EF11E9-8BCFDE4A-CF852F76@10.0.77.4
CSeq: 101 INVITE
Allow-Events: presence
Content-Length: 0
Jun 18 10:59:42.509: //2247/AF677048A3C6/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 404 Not Found
To: <sip:777XXXXXX7006@CUCMIP>;tag=5312677~08189fa9-9b8b-44b1-b46f-6453003f86dd-18881352
CSeq: 101 INVITE
Reason: Q.850;cause=1
Server: Cisco-CUCM10.5
Content-Length: 0
Jun 18 10:59:42.517: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
ACK sip:777XXXXXX7006@CUCMIP:5060 SIP/2.0
Date: Tue, 18 Jun 2019 10:59:42 GMT
Max-Forwards: 70
CSeq: 101 ACK
Allow-Events: telephone-event
Content-Length: 0
CUBE config:
dial-peer voice 777 voip
description OUT-TO-CUCM
destination-pattern 777T
monitor probe icmp-ping
session protocol sipv2
session target ipv4:CUCMIP
incoming called-number 777T
codec g711alaw
no vad
Any calls will come with 777 prefix from any gateways. CUCM hunt pilot waiting for 777XXXXXX7006, but cause=1 for calls seems there is a CSS problem
Content for Community-Ad
Spotlight Awards 2021
