CUCM 10.5 Subject Alternate Name in tomcat (alternatehostname)
Jason Aarons
Level 6
Level 6
Is this the right syntax to set a a Alternate Subject Name in CallManager 10.5 for Tomcat?
set web-security CH "Hawaii Department of Boating" Honolulu Hawaii US ton.state.hi.us HI-IT-UC-CM-P.dot.state.hi.us myphone.ton.state.hi.us
I am worried about the OrgName having spaces in the name.  Will CallManager CLI recognize my quotes around "Hawaii Department of Boating" ?  Am I supposed to put orgunit ?  I wish the online set web-security ? had some examples or cisco.com had some examples.  Here I I am adding a alternate hostname of myphone.ton.state.hi.us for UCMUser Web Pages.
Names have been changed to protect the innocent :)
Jason Aarons
Level 6
Level 6
That didn't work, error below;
Expected 4 mandatory and up to 2 non-mandatory parameter(s)
but 8 parameter(s) were found
Executed command unsuccessfully
Error executing command
admin:
You have to specify the Organization, State, Country and Department names to get this to work. If you ? that command, it should tell you the order.
Here it is for your reference:
admin:set web-security ?
Syntax:
set web-security orgunit orgname locality state [country] [alternatehostname]
orgunit  mandatory   organizational unit
orgname  mandatory   organizational name
locality mandatory   location of organization
state    mandatory   state of organization
country  optional   country code can not be changed
alternatehostname  optional   alternate host name
Please rate useful posts.
